Critical Thinker
I have heard this terminology used in racing terms for manual vehicles.
Can someone shed some light on what the benefits are for 'double clutching' and why some racers do it? If there is another thread on this subject, please direct me to it.
Cranky old bastard
Used to be common in the good old days; before syncros and was used to 'line up the cogs' at each gear change.
Critical Thinker
Thanks olfella, is it a necessity for todays gearboxes or a thing of the past?
it is a method of changing down normally
you push clutch in, pull out of gear release clutch rev, re clutch and put in gear, pretty simple but hard to master not needed today normally, as gearboxes have synchros etc to allign gears and allow to engage |
Yep, it's pretty simple. Clutch in, neutral, clutch out, match revs, clutch in, select new gear and the release.
Much more satisfying to not clutch non synchro boxes at all, but that takes getting used to and can sound very bad if you get it wrong. Many trucks use non synchro boxes, cars started using synchro's in about the 30's. Some race boxes still use no synchro's, but they don't double clutch the shifts. If you're thinking fast and the furious, that was just rubbish. Double clutching had nothing to do with anything. Stupidest line ever. - edit. You can practise it on your normal cars, but it will just wear the clutch out twice as fast. You won't know if you've got it right because the synchro's will match it all up for you. So very little benefit, other than getting the basic co-ordination. If you've ever heard a truckie talk about a road ranger, it's a non synchro box they were referring to. If you can't find it, grind it. |
#6 | |||
Cranky old bastard
#7 | |||
... Fear it!
Takes ages to master Shav ... but u have an Auto
#8 | |||
I could also double clutch if I wanted, but why bother. |
#9 | |||
Cranky old bastard
Its easy to master once you got it.. I drive 13 - 18 speed road rangers quiet easily now..
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
#11 | |||
2003 BA Fairmont Ghia 4.0 Blue Pearl Last edited by Sloth; 28-07-2008 at 07:01 PM. |
#12 | |||
A philosopher is a person who finds a problem for every solution . :Reverend: 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
#13 | |||
![]() Join Date: Oct 2006
I always called it double declutching and it was the only way to drive the old Jeep we had on the farm when I was a kid. Non synchro gearboxes were old technology even then - out 1950's farm tractor even had a 5 speed sychro gearbox. The Willy's also had synchomesh originally it was just that they had worn to the point that they no longer worked.
Through lack of practice I have forgotten how. Though as I found out several years ago when asked to drive a similar old jeep, my sub-concious still knows how. I automatically double declutched fine without being aware of it until someone commented on what I was doing and I became concious of what I was doing - after that I couldn't do it - I think I was thinking too hard about how to do it and waiting for the inevitable gear grind each time. See http://www.madabout-kitcars.com/kitcar/kb.php?aid=190 Quote:
regards Blue |
#14 | ||
Critical Thinker
cheers for the info fellas. Thats explained a few myths for me.
Yeah I have heard it from a few sources including fast and furious and other films. But I was never sure if it was something worth doing. Obviously not by the sounds of it.
#15 | ||
Yer not really something that is really applicable for today's cars, still widly used to drive trucks though. Mind you I prefer to not use the clutch in the truck but it does take alot of practice and soem ordinary sounds lol.
#16 | ||
Bugger! 1390mm too long!!
In my old Freightliner and Mack, due to my long legs i had trouble reaching the top of the steering wheel and often had to lean forward to turn corners if i wanted to use the clutch. I was forced to drive without the clutch up and downshifting. Now in my Powerstar i can sit very comfortably, still down low in the cab and and can use the clutch and turn corners without leaning forward. I feel much better about my driving now.
Talking to an engineer at Allison one day about this and he said to me that the clutch is there for a reason. It should be used. While you may appear skillful driving without the clutch, any employer would prefer someone who prefers to use the clutch.
'06 Freightliner Argosy C15, Smartshift Auto, bugger it... '02 VY SS Commodore Ute "WhiteNoise" 6 Speed 5.7 litre Custom XR Boss Bulge, OTR CAI and MAFLESS Tune Stage 3 Cam 297rwkw (now sold) ='( '05 Blaze BA MkII XR6 "GOLDMEMBER" Semi-Auto Premium Sound LED Screen =D |
#17 | ||
growing up is optional
As well as using it to help engage gears by equalising the speed of the gears so they mesh more easily, race drivers use it on downshifts to prevent 'compression locking' and help stabilise the car during braking.
Imagine if a V8 supercar driver went flying into the chase at Bathurst at full noise, hit the brakes, selected 4th gear and popped the clutch. The back end would lock up quicksmart! |
#18 | ||
Snake Oil
Just a small point if you cannot double declutch you probably cannot heel and toe which means that you cannot balance a car at its ragged edge
Even heel and toe with a blip on the down change is better than slamming down a cog then back on the brakes etc Riding bikes /cars quick is all about balance and controlling the weight shift Dude next time V8 supercars is on watch very carefully when they do the footwell shot it shows how they balance the car if you are driving an auto learn left foot braking...........the first time you do it you will either break your nose on the dash or slam into the car in front but keep practising Driving cars is a foot skill not a hand skill.......cheers
Snake 2015 Mercedes C180 Coupe White/Black 2011 FG GS Ute manual #246 White/Black 2010 Chrysler Sebring limited hardtop Silver/grey 2003 UX Explorer V8 White/grey 2008 Suzuki Bandit GSF 1250 Black 2016 Victory Cross Country Tour Black 2011 Glastron GT 185 (USA made bowrider)White/Black 1988 Komatsu FG10 Forklift FPV & XR Owners Club of Victoria #975 Ullysees Member #18,554 |
#19 | ||
BOSS 5.4L Enthusiast
Still Learning the Art of Heal - Toe to be honest, i find it much easier in alot of friends older smaller cars (E.g TX3 AWD Turbo) than in my BA Falcon and i have decent sized feet (Size 12-13), is is just me or does it seem like the Brake sits just a touch high to give the throttle a proper Blip with the Less than sensitive Electronic throttle in these cars?
Maybe an Edit will help or am i missing something? |
#20 | ||
Never late with a V8
In the K-Dub im double clutching all day long, its a to learn correctly but once you do its really quite simple, Tacho is your best friend... when learning
My Rides (Daily)2004 Explorer V8 Limited (Project/Cruiser)XE Fairmont Ghia- 351 Cleveland, Toploader (Work) 2014 Kenworth K200 Aerodyne (Classic) 1969 Mini K, 1340, twin SU's The beginning is near!!! Body by Ford. Soul by NudgE
#21 | |||
Spr Jenkins
I'm kinda wondering if its even worth learning in the BA because its so hard to do.
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands" -Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times -Chuck Norris doesn't sleep. He waits. -Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain. |
#22 | ||
some people ive spoken to say this and they mean when in wet or dry and want to drift without the handbrake or other means,as you come into a corner and the weight of the car(if your goen quick enough)starts to offload and your given it throttle punch the clutch and be ready to catch it.I used to do this(and still do)with my first car a xf 3.3 carby,open diff in my pops paddock.doen circle work and no crapy keyholes but huge controlled drifts around a goat track and when it started to oneleg i would smash the clutch or feather the brake to get both wheels to spin again.unless youve got a safe place to practice i recommend not to this as ive had a lot of practice and was shown a few tricks by a couple of my uncles.highway patrol officer and driver instuctor for the sydney police force.both are extremly good steerers.retired now.
#23 | ||
Start riding a motorbike, where heel toeing is much easier. If you don't rev match the downshifts, you'll end up on your . Unless you've got a slipper clutch.
#24 | |||
Afterburner + skids =
![]() Join Date: Dec 2004
#25 | |||
#26 | ||
Nat D
it's used alot in racing, especially drifting. when u do it alot, it becomes habit and people get in the car and ask what the hell your doing.
old ride#1: ED XR6 5 speed-gone to new home:( old ride#2:dumped EL fairmont 5l new ride: Winter white AU2 XR8-manual |
#27 | |||
You don't physically heel-toe, but you do the same thing as heel-toing in a car. Using the clutch, brake and gas at pretty much the same times. It's like saying you floored it at the lights in a motorbike. You don't physically floor it, you just twist it or snap it. But everyone knows what you mean. |
#28 | ||
Yeah thats what I thought. I would hardly call it heel toeing though.
#29 | |||
I'm not seriously having a go at anyone ![]() ![]() Like i said, i'm not having a go at anyone, its just something amusing that i've noticed. EDIT: I've tried it a few times in my BA but as someone posted earlier, the brake feels way too high. I've got bigish feet but it feels like i need clown shoes on. Tried it once or twice in my old work car (90's rodeo) and while the pedals in that felt perfect, i was still pretty bad at it ![]() EDIT2: I guess that means i don't measure up ![]() |
#30 | |||
Parts bin special
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
