Old 22-01-2009, 09:32 PM   #1
Javus
Default Cougar Parts
Hi all from VIC,
Just bought a 99 Cougar & it turns out that it kinda needs a few bits & peices after getting a road worthy assesment this morning. Wondering if anyone can help. Does anyone know of any wreckers in VIC that have any cougars?
RRW - (Required for Road Worthy)
Parts I need:
1. rear parcel shelf plus the plastic part that holds the shelf - (the part were the latch is to pull down the back seats)
2. 2002 centre console because mine (99) shakes a fair bit plus it has cassette tape holders lol!?! and the cup holders... forget it. the only one I trust is between the two seats.
3. RRW: Headlights
4. RRW: x4 full brake components (discs, pads etc)
5. suspension - springs, struts should I get them new?
6. CD player, I think the cougar one is mdl 4600 or something
7. RRW: passanger door central locking mechanism.
Thanks in advance ppl.
Javus is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2009, 11:19 AM   #2
Dshibi
A New Focus In Life...
Dshibi's Avatar
Welcome to the forum Javus, I've sent you a PM regarding your other issue...
As for the above I know there are a number of online resources which some members would be able to list, I'd honestly even try ebay for some of your needs but make sure you get the right parts for what you want.
I'm not sure there'll be too many wrecked Cougars about for parts and I'm thinking the Ford option might be a bit costly...
Dan
2010 Ford Focus XR5T - Performance Blue
2XS - Continental - Dreamscience - Elevate - PumaSpeed - Whiteline - XForce
Dshibi is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2009, 08:28 PM   #3
Javus
Thanks for the welcome & reply.
I read a few 'bad purchase posts' on forums... I agree, FORD option is too costly but sometimes you have to go to them. e.g could not find the rubber covers for the brake and clutch pedals anywhere, had to order them from Ford. They also said that it's nearly an obsolete item. $21.50 for the brake & $16 for the clutch (in $AUD for those else where)
Has anyone got step-by-step instruction to open the interior door cover? I removed all the screws I see (behind the cougar logo on the handle etc...) but I could not get it off + didn't wont to damage, I F*K up like that before lol.
Cheers for the advice Dan
Old 27-01-2009, 03:28 PM   #4
thearrow
Welcome to the boards Javus.
Everything you could ever want to know about your Cougar is here
http://www.newcougar.org/
register and the information is endless.
If you are after parts then check here and look under Mercury - Cougar
http://www.rockauto.com/
I can highly recommend rockauto and I get ALL my parts from them including plugs & leads and they deliver to your door within 3-5 working days.
Good Luck and welcome.
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 12:13 AM   #5
Thunderbird
.. be carefull of buying in headlights.. you need to look at the right hand drive headlights.. not US headlamps, check the dip angle.. if yours are tarnished/foggy.... clean them down with super fine wet & dry.. and polish them up.. The brake parts are available locally from DBA (Disc brake Australia) or cheaply enough from www.usafordsp.com .. the Shocks the same or from Kmac or Heasman Suspension in Sydney.
Supercheap will also get the shocks in if needed but you need to find somebody with a brain their..... price is ok.. Remember the car is partly European too.. the costs of USA freight is not cheap anymore, for lightweight stuff its ok. Most ebay cheap stuff is just that.. but no guarentee either past the feedback.. if you recieve it. Rock Auto is an exception.. good if in stock (they may ship from 3-4 places so it may not get to you at one time.. check.. & "if the parts are right", as stated but if not - especially heavy stuff like brake parts - check their return policy too. The shocks.. Bilsteens are GREAT but expenive.. also grab a copy of Parts Peddler or Parts Locator.. both have many Cougar parts sources, www.allford.com.au in Braeside helped out a while back too.. seemed ok on price.
Thunderbird is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 11:20 AM   #6
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
we have a few cougars in stock aswell.
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2009, 05:15 PM   #7
thearrow
I found this link on my wanderings around the net and would suggest they would be OK for the lights. All you would have to do is get them adjusted for RH drive (it is an easy job). Good for a lot of other parts as well and recommended by the guys at NECO.
http://www.teamfordparts.com/partloc...?siteid=214270
Old 03-02-2009, 12:08 AM   #8
Thunderbird
Javus.. what actually wrong with your headlamps..??
Old 10-02-2009, 01:25 PM   #9
FumDuk
FumDuk's Avatar
hey, I found ebay-uk have heaps of cheap cougar parts... although i'm still broken down :( and cant find an a/c compressor that fits
2010 Ford XR50 - Viper
2001 Ford Cougar - Candy Apple Red
FumDuk is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2009, 01:28 PM   #10
FumDuk
FumDuk's Avatar
I called this number and they said they don't have any cougars ???
Old 10-02-2009, 02:45 PM   #11
thearrow
FumDuk I checked Rockauto for you and the all up price for a NEW compressor including delivery to Australia was U$331.35 = about A$500.00.(Look under Mercury/Cougar)
Mate, all you need is a credit card and you will have your compressor in a few days delivered to your door.
I have used Rockauto a number of times and can highly recommend them.
Old 11-02-2009, 11:29 AM   #12
FTGAutosalvage
Commercial Sponsor
we have 2 in stock.......
we have a compressor on the shelf ready to go......
Old 11-02-2009, 05:47 PM   #13
Javus
Hey Thunderbird,
I think my car was involved in a very light front bingle which broke the headlight supports so I cant screw them in properly (loose)
** Thanks all for your replys & reccomendations. They have proven to be very very helpful.
e.g lower control arms for my cougar cost roughly $500 - $600 e.a from Ford. Got a quote from USAFORDSP.com for $179 e.a wtf FORD stop ripping us off.
https://pontiworld.com.au/usafordsp/...hp?cPath=21_36
http://www.ftgautosalvage.com.au/Default.asp these wreckers... awesome, found the part I needed for the parcel shelf plastic cover $25, FORD once again unbelievable price.
Old 11-02-2009, 10:04 PM   #14
FumDuk
FumDuk's Avatar
Yep, I ordered one 3 months ago... completely different to the one I took off. mounts are in the same place, but the hoses are located in a completely different position =( and I'm still without my car. . .
(sorry Javus, i'm hijacking ur thread a bit... i'll stop now _2: )
Old 12-02-2009, 08:59 PM   #15
cat1999
blueoval
definetly shop around Ford are very expensive $75 for a wheel nut that you can buy from outobarn for a bout 2.50 - 5.00
front brake pads fords $175
supacheap about $50
hope you dont have probs with the electrics either abs module $4000 to rebuild
and there are a number of other problems you need to keep an eye open for
cat1999 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2009, 04:25 PM   #16
Javus
No probs FumDuck.
Does anyone use R1 concept brake rotors? what style is better: drilled, slotted, both or none?
Any recommendations for x4 rotors plus pads w/sensors for 99 cougar? for everyday spirited driving Also need a reliable, honest mechanic in Melbourne
Old 16-02-2009, 07:10 PM   #17
Dshibi
Dshibi's Avatar
Javus,
I've got the EBC Green Stuff pads on mine and they seem to work fine.
I've also had the rotors changed for Magnum Cross Drilled Rotors. I don't know if they're better or worse than slotted, but I liked the look more than anything else...
Dan
Old 16-02-2009, 08:39 PM   #18
Thunderbird
Default stuff..
AC Compressors are absolutely DIFFERENT to the USA variety... as FumDuk also said and found out too the hard way.. and too much probably to post back now.. .. .. DO NOT ORDER FROM THE USA, from Rockauto or any US ford dealer.. ..
Maybe try sponsor FTGAutosalvage they said they had a good used one just a couple of weeks back.
Jarvis "Any recommendations for x4 rotors plus pads w/sensors for 99 cougar? for everyday spirited driving Also need a reliable, honest mechanic in Melbourne" - John Osborne at American Car Repairs at Elsternwick.. 9596 0362. .and older guy who has been in the industry for about 40 years.. .. he's not a reference center.. so be polite.. but honest and knows how things work.
Old 21-02-2009, 10:16 PM   #19
FumDuk
FumDuk's Avatar
Hey Thunderbird (my dream car is a '62 Roaster :P )
Yep, I ordered from FTGAutosalvage, $265 for the compressor + $180 for fit and gas at my local ford and I'm back on the road. Sooooo happy.
Thanks for your help guys
RicK : : :
Old 18-07-2009, 04:25 PM   #20
bunter
F.T.F Member
bunter's Avatar
my wife and i just replaced both lower controll arms on our 2000 cougar and to buy both was cheaper than just buying one from ford.
Ford price $600 each
price i paid each was $205.40 +gst AU, place down near the gong
https://pontiworld.com.au/usafordsp/...af1737e835ca6a.
ordered them thursday afternoon and they were knocking on my door friday morning at 7:30am, freight was $16
does anyone know were i could get hold of steering rack mounts from ??????.
Family Stable
Dark Green EF Mont (The Green Meany)
Lightening Strike 2004 TS Territory
Old Rides
White V8 EB Mont
Ebony Black 2000 V6 Ford Cougar
bunter is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2009, 07:48 PM   #21
FumDuk
FumDuk's Avatar
Give Ferntree Gully Auto Salvage a call, they helped me out with my a/c compressor a while back. Charged a little more than I thought they should but better than my alternatives ...
Ph(03) 9758 6900 Fax (03) 9758 6899
Rear 1152 Burwood Hwy, Ferntree Gully, Vic, 3156
Old 20-07-2009, 10:27 PM   #22
REDDYZ
REDDYZ's Avatar
Hey FumDuk what was wrong with your A/C compressor? I have similar issue. The compresser on my car wont turn on, but its just because of blown diode. It costs $29 and can be ordered only by ford dealers from the factory.
Yogi
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 10:38 PM   #23
bunter
F.T.F Member
bunter's Avatar
ford need to have there balls cut out ripping people off.
KYB front struts USA ford service parts $348 a pair
Struts from ford stock $650 +GST Each not a pair
im trying to get my wifes car back on the road as she is willing to spend a few grand on paint and mags and custon graffics and paint work with ford screwing people on parts my wife wnats to sell her beloved cougar.
Family Stable
Old Rides
White V8 EB Mont
Old 21-07-2009, 03:12 PM   #24
thearrow
There is no doubt that FRAUD parts are way over the odds when you can buy the same parts on line from overseas. As it happens shipping costs have come way down so order all the parts you want.
My preferred supplier is
If you want larger parts e.g. body panels I can arrange it for you.
Old 21-07-2009, 04:10 PM   #25
FumDuk
FumDuk's Avatar
Yogi
Hey, Mine made smoke and then flames and lots of screaming :P I needed a new one : lol (oh, and it did it 2,000km's from home)
Rockauto is great, but I found out the hard way that the a/c compressors they stock dont suit aussi cougars :(
RicK
Old 21-07-2009, 04:37 PM   #26
bunter
F.T.F Member
bunter's Avatar
i been dealing with pontiworld.com.au great service and pricing
Family Stable
Old Rides
White V8 EB Mont
Old 09-10-2009, 11:31 PM   #27
Bobman
Regulator
Bobman's Avatar
Hi,
Sorry to bring up a few month old thread.
My sister's friend recently crashed her Cougar (front only) and no had no insurance, so she's asked me if I can strip it to recoup some cost.
EOI I guess, would there be much interest here for parts? It's red or maroon I think. eBay doesn't seem to have much on there for these cars, so the forums might be the way to go. Any Cougar specific forums in Oz or is this place my best bet?
Cheers.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2009, 03:10 AM   #28
bunter
F.T.F Member
bunter's Avatar
what options does it have ?
Family Stable
Old Rides
White V8 EB Mont
Old 10-10-2009, 08:47 AM   #29
Dshibi
Dshibi's Avatar
It's never good to hear about a crashed Cougar, but at least the parts can live on!
There's no 'Australian' Cougar forum, so here's probably your best bet. The other main forum we peruse is over at newcougar.org, but all the Aussie users who view that one are also on here.
Dan
Originally Posted by Bobman
Hi,
Cheers.
Old 10-10-2009, 07:19 PM   #30
Bobman
Regulator
Bobman's Avatar
Thanks for your help, Abraxas
It's a 2000 model, auto. Has leather heated seats and is red.
What extras did these cars have? Don't see many around here. Car is going through some insurance stuff so I guess a few weeks before it'll be ready.
Anyone know what prices and what parts are most popular? Cheers again.
Regards
Bobby
Current Cars:
Previous Cars:
