Old 02-04-2009, 08:21 AM   #1
NJM586
Default Changing oil in a Wq fiesta
as topic says can this be done ? i no i may sound stupid but i was reading somewhere that the manual gearbox is sealed and the oil cannot be changed is this true? i have tried looking for the plug and were to put the oil but i cannot find it any info will help guys
cheers
NJM586 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 03:52 PM   #2
Ben85
Ben85's Avatar
I'm not 100% sure but i have heard the same thing. As far as i kno the box is sealed and the oil cant be changed.
2006 WQ Fiesta Zetec Sea Grey
Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp.
Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction.
Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's.
Ben85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2009, 09:46 PM   #3
xr4racer
xr4racer's Avatar
There is no drain plug. There is a is a filler plug tho. It is behind the motor, sort of down and left of the battery when looking from the front. The plug is held in by a pin that has a clip on it. If you can put the car on a hoist itis easier to find from below.
Mike
www.ttcracing.com
xr4racer is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2009, 07:44 AM   #4
robjh80
robjh80's Avatar
So how do drain the oil from the gearbox if there's no drain plug?
Surely the oil has to be replaced sometime?
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2009, 11:53 AM   #5
xr4racer
xr4racer's Avatar
u need to suck it out. I have an oil changer that does it but you can buy hand pumps (like a big syringe).
Mike
www.ttcracing.com
