19-04-2009, 06:38 PM | #1 | ||
Falcon Unbelievable!
Heyas,
I seem to have a problem with a faulty horn I have been told its the horn pad and needs to be replaced (plus I like my cruise control and the horn relay controls that too :( ) I have been told that the horn pad and airbag are one unit and cannot be bought separately is this right or what? I don't really feel like paying $500 for an airbag and horn pad when my airbag is perfectly fine.... Just thought I'd tap the knowledge pool and see whats fact and whats b/s. Cheers, Chris |
19-04-2009, 07:08 PM | #2 | ||
you need to change your clock spring and their one on ebay i know cause im selling it
19-04-2009, 07:14 PM | #3 | ||
If it's the horn, then yes, you need to replace the complete airbag assembly. Or just fix the horn using momentary off/on buttons.
19-04-2009, 07:21 PM | #4 | |||
Bugger! Hey JC what are momentary off/on buttons is it like a separate switch? |
19-04-2009, 07:25 PM | #5 | |||
The same thing happened to mine on a previous AU and I just made my own switch, disconnecting the factory horn pad. I used a little momentary red switch from Dick Smith/Jaycar. Finding a way to mount it is the hardest thing, but there's plenty off room next to the airbag and cable ties work well.
19-04-2009, 07:31 PM | #6 | |||
Cool thanks might have a go at that, 'cause I don't feel like forking out $500 for a new airbag when I don't need one. |
19-04-2009, 10:00 PM | #7 | ||
if your horn and cruise control have gone walkabout it will be the clock spring this is a part in behind the steering wheel that allows the steering wheel to turn with out twisting up the wires yes jc it could be the horn pad but highly unlikely and would you run new wires from the horn and drill holes in your dash for a button that would look like **** i like forums but i dont like post huggers who just type for the hell of it
19-04-2009, 10:33 PM | #8 | |||
19-04-2009, 10:39 PM | #9 | ||
right mate like said post for no reason and just have a read of the first post and i waiting for my appoliges "newbie" haha
19-04-2009, 10:50 PM | #10 | |||
So, SirHenry, best way to diagnose this: 1. Look up your owners manual and remove the ABS fuse(s). If it's an AU1, they should be fuse 17 and 21. 2. Undo the airbag assembly from the steering wheel. You will need a number 27 5 sided torx bit to do this (GK has a write up somewhere that details the steps). 3. Turn the airbag over, and disconnect the red connector. 4. Get a piece of wire an use it to short the two wires on the plug (not the plug on the airbag end - the other one). 5. If the horn sounds, then I would say that the clock spring is OK. If it doesn't, then the clock spring is buggered. Some may say an easy way to check is if your cruise works, but your cruise might not work due to a tail-light globe not working (You could check that first too, of course). If it is the horn pad, I can send you some pics of how to get the horn working again. Or you can check eBay from time to time for an airbag assembly. If it is the clock spring, and you are not confident in fixing it, then replace it (a second hand one from the wreckers would do the trick).
19-04-2009, 11:11 PM | #11 | ||
nice apology JC although bit long winded _2:
19-04-2009, 11:15 PM | #12 | |||
Sorry should have put that in my original post Its a 2000 Series 1 AU Classic Yep problem definitely has definitely been diagnosed by one of the best, the only reason my cruise control doesn't work is because we took the fuse out as an interim measure to stop it blaring. The most likely culprit is believed to be one or more of the "buttons?" not working correctly. Other bad bit is disconnecting the battery to fix it, damn thing doesn't work manually resetting the ECU it seems to need Ford to reset it. Last edited by SirHenry; 19-04-2009 at 11:22 PM. |
19-04-2009, 11:24 PM | #13 | ||
well then i apologise too
19-04-2009, 11:31 PM | #14 | |||
20-04-2009, 02:42 AM | #15 | ||
Pro Street Au Ute
i had the same thing happen but i disconnected wires directly from horn i haven't bothered fixing mine though i use my fingers instead lol.
20-04-2009, 09:44 AM | #16 | |||
gone fishing
This exact same thing happened to my series 1 about 2 years ago I bought a "horn pad assembly" took it to a auto elec and about 20 mins later drove out with a working horn. They asked if they could keep the old one to show the apprentices what happens with the air bags when they go off.
Cheers Whiskers |
