Old 03-08-2009, 01:57 AM   #1
tazza255
1979 ZJ Fairlane 302c
tazza255's Avatar
Default someone attempting to steal my car!
hi all,
someone has tried to steal my car tonight i was inside with the door to my veranda open when i heard the noise to my door opening (destinct creaking sound) when i went out to see what was happening i heard what sounded like someone climbing my colourbond fence, i went downstairs and checked my car,
they managed to get my cars back door open,
what should i do ?
I cant afford an alarm for at least 2 weeks (biils)
Cheers,
Jerry.
CARS:1979 ZJ Fairlane 351 DuelFuel
tazza255 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 02:21 AM   #2
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
Dont oil the hinges for starters. Id report it to the cops. Maybe one of those cheap flashing LED's will be enough to deter the blighter?
Jaycar CAT. NO. LA5082 its $7
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 02:24 AM   #3
tazza255
tazza255's Avatar
if i wasnt in a unit block id borrow one of mums rotties & put him in there
Old 03-08-2009, 04:32 AM   #4
blownv8au
Pro Street Au Ute
blownv8au's Avatar
disable you engine as much as possible take out your rotor button, disconnect ignition wire on coil and put a rag in the carby. basically theft-proof it because you can basically replace anything inside it but if they take it they'll f it. alternatively stay up for the next couple of nights with a bat handy.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 07:41 AM   #5
paule11
plastic snake on the ground between car and door
paule11 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 07:59 AM   #6
dandandandan
dandandandan's Avatar
Thumb tacks on the seats?
Without an alarm there isn't much you can do unfortunately unless you stay up every night :(
You'd want to make sure your insurance was paid for just in case something happens.
www.bseries.com.au/action&action
BA MKII XR6T, Vixen, Leather, Sunroof.
Stock as a rock... Till after xmas :evil3:
dandandandan is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 08:03 AM   #7
2stroksmokr
Imagine if you forgot you put them there in the morning
2stroksmokr is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 11:02 AM   #8
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Fair chance just druggies looking for a buck too.
I had my old XD ESP sitting in the streetfront drive for ages and found it unlocked one day with the glovebox open and generally rifled through...but otherwise undisturbed. Lets hope thats all it was
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1
A stereo that happens to have a XR5 wrapped around it
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 11:11 AM   #9
Tim27
Tim27's Avatar
someone tried to steal my car the other day too......bastards broke the keyhole cover on the drivers door.
Tim27 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 11:17 AM   #10
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
If you haven't already. Take out insurance!
With AAMI you can ring and get coverage, and get them to send the invoice out, which gives you 2 weeks to pay. Also, consumer rights mean in the first 2/4 weeks you can pull out. Good if your short on dough to get the initial coverage, then work out how to keep it from there.
Help lessen the panic anyway.
PS Do what was suggested above. Re: remove distributor rotor button, rag in the carby and ignition coil lead.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 12:12 PM   #11
DOC
DOC's Avatar
Turn the stereo flat out, take the horn relay wire and connect it to the brake light switch behind the pedal (in addition to the above
turn ignition / start radio flat out, not a good thing to try and sort if stealing a car / foot on brake pedal horn sounds, now this causes real problems as you can imagine and is very easy to quick wire
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 12:39 PM   #12
blownv8au
Pro Street Au Ute
blownv8au's Avatar
good suggestion that would work a treat.
Old 03-08-2009, 12:45 PM   #13
BlackLS
yum
Horn to the interior light relay - door open and BAM!
Put a cheap microswitch somewhere to disable it (in the grill or windshield shroud) so u dont wake the whole neighbourhood when you open your car
2005 LS Focus LX
250,000kms.
Old 03-08-2009, 03:07 PM   #14
smally289
growing up is optional
smally289's Avatar
Trade it in on a new Commodore - even thieves dont want a VE!!!
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 03:30 PM   #15
XR6Runner
Sling Shot
That's funny because you know who scored number 1 position as 'most stolen vehicle' for the last few years? Commodore!
But some of the ideas are a pure genius, I'm going to try some of these out. Turning the volume all the way up is one hell of an idea and such a simple one too!
XR6Runner is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 04:02 PM   #16
Fairlane
V8 Powaah
Fairlane's Avatar
Definately remove dizzy rotor button, tension lead or install a kill switch. It will stop the randomns from stealing it. But unfortunately if someeone is really set on knicking it your stuffed... if you afford some get some fire n theft insurance.
And No 1 get a sensor/security light for your yard ($25 at bunnings) , scare a thief off more than anything and should wake you up.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 07:53 PM   #17
AC/DC
" Let there be Rock "
AC/DC's Avatar
Leave $10 and a note saying "No Money inside" under the wiper blades, so they will just take the tenner and dont bother breaking in...........
AC/DC is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 08:17 PM   #18
Yaw
Ford Fanatic
Yaw's Avatar
Did you ever see James Bond "for your eyes only" ?
I love the burglar proof lotus, (had the sticker on the window stating that)
A guy tried breaking in...the entire car blew up...LOL
I think thats a bit extreme, I know you said you can't afford one, but check this out:
http://cgi.ebay.com.au/NEW-Rhino-GA-...d=p3286.c0.m14
It has 1 day left and is currently $1.00 with $20 for postage
EDIT:
One other suggestion (may depend on your living arrangements)
If you have a tow bar, get a big chain and padlock, Dynabolt the chain to the concrete and then pein the dynabolt over with a ball pein hammer so the nut will not come off, padlock the towbar to that. (not the tongue that can just be unbolted)
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 08:27 PM   #19
ThePistonHead
Shame Holden, Shame
ThePistonHead's Avatar
Unplug battery? By the time it takes the fools to realise what's going on hopefully they will give up and move on.
Not fun trying to hook up battery terminals in pitch black.
Essendon FC '11
EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer|
METALLICA
ThePistonHead is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 08:39 PM   #20
Rodp
Regular Schmuck
Rodp's Avatar
On my early cars I had an auto-lecky earth the coil to a cut off switch.
Many laughed but I had an HX kingy (ok, shoot me) with a wild 350 back in 1991 parked in the old man's driveway (much to his disgust being a Ford man). They pushed it out down the road, changed the battery but there is stood.. still mine the next morning.
Old 03-08-2009, 08:58 PM   #21
tankclare
BURN RUBBER NOT OIL
tankclare's Avatar
As others have said try the rotor button trick and killswitch etc. But lets face it if someone wants it bad enough they will take it. Mate had his car stolen and it didnt even have a battery in it. The bastards put one in it. Have also heard of cars being rolled out of driveways, pushed down the road and towed away. Crazy stuff.
But hopefully it was just some dead beat after a quick dollar who got into your car. The ideas people have put on here are classic.. Try them
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l
[SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218
tankclare is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 09:12 PM   #22
irish2
Coil kill switch is the way to go. Even set up 2 and only turn one 'off' that way if they go looking for it having two under the dash could confuse them long enough to alert someone.
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 11:36 PM   #23
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Not a real nice one, but razor blades underneath the door handles is enough to alert the owner of the car, not to mention the woodbe thiefs surprise.
Yes it is illegal if you happen to have them used and left in place, but effective none the less.
Just got to remember they're there in the morning.
Cheap effective short term alternative, which i know not everyone will agree with
Old 03-08-2009, 11:50 PM   #24
Linkachu
Dissconnect the cat, thatd surely alert someone and theyd get pulled over for sure if they got away with it.
But there are some brilliant ideas here.
Linkachu is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2009, 02:42 PM   #25
Assassinbm
Assassinbm's Avatar
Trunk Monkey the only real answer!!!!
http://www.youtube.com/watch?v=geynA...eature=related
I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle. - Winston Churchill
Assassinbm is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2009, 05:49 PM   #26
BPXR6T
I used to pull the rotor button out and throw it in my pocket when parking down at the shops.
