For anyone who still uses the phrase "there's no replacement for displacement," this makes you really think twice.
http://farmindustrynews.com/trucks/0...oboost-engine/ I will copy the text here, in case there is an embargo which forces the page to be taken down. Good to see a written comparison to the 5.4L V8 in the same vehicle. .................................................. .............................. A BOOST UP Sep 1, 2009 12:00 PM, By John Gilbert Ford's EcoBoost engine technology increases torque, improves fuel economy and lowers emissions All it took was an impromptu drag race at Ford's Dearborn, MI, Development Center to convince me of the merits of the company's new EcoBoost engine technology. Journalists spent a day there learning about the new 2009 vehicles, and two of us ended up last in line on a straight test strip where we could compare an F-150 pickup with an identical vehicle powered by an EcoBoost V6 engine. All Ford officials had left the area, and only two engineers remained to ride along with us on our acceleration tests. After requesting one last run in the F-150 with EcoBoost, I waved the other journalist to pull alongside in his F-150 with the 5.4 V8 and suggested we try a drag race on the wide, straight, mile-long strip. The engineers said they weren't sure we were allowed to do that, but I assured them — with no authority whatsoever — that it would be okay. Quickly, I told the other journalist to count down, “3-2-1-GO!” He did, we both hit the gas, and I was astounded both at how swiftly my EcoBoost-powered vehicle took off and how rapidly his V8 F-150 grew smaller in my outside mirror. Ford first introduced EcoBoost in cars like the Taurus and Lincoln MKS and crossover SUVs like the Flex. Ford's standard 3.5 V6 engine turns out a solid 263 hp and 249 ft.-lbs. of torque. The EcoBoost V6 in car form jumps to 355 or 365 hp, and to 350 ft.-lbs. of torque, computer-controlled to maintain that peak from 1,500 to 5,250 rpm. In its auto and crossover applications, the EcoBoost required all-wheel drive rather than front-wheel drive to handle the increased torque. “The F-150 will be the first application of the EcoBoost to a rear-wheel-drive vehicle,” says Alan Hall, EcoBoost marketing manager. “Because of that, we'll be able to get even more torque out of it. We'll have a similarly flat torque curve, and we're going to have a special transmission to handle what I would guess will be somewhere over 400 ft.-lbs. of torque.” Technically, Ford created its first EcoBoost by taking the high-tech, two-year-old, 3.5-liter V6 and reinforcing it throughout. A stronger but lighter die-cast aluminum engine block was fitted with a crankshaft and connecting rods, both made of a higher-grade alloy for greater durability. Oil-cooled pistons, to withstand greater heat, have cylinder heads machined for direct injection. The dual-overhead camshafts are set for variable timing of the valve train to assure optimal performance, lower emissions and better fuel economy. Turbocharging compensates for the fewer cylinders and smaller displacement, and Ford worked with Honeywell-Garrett to develop dual water-cooled turbochargers. Typically, turbochargers operate by directing a stream of exhaust flow to spin a turbine wheel, which powers a compressor that force-feeds an increased volume and velocity of airflow, sucking gasoline along with it to the engine. In the EcoBoost system, smaller turbines provide quicker spooling time, and, combined with the direct-injection system and computer control, the usual lag in power application is eliminated. Instead of squirting the same air-fuel mixture into all cylinders at once, the Bosch-designed direct injection is calibrated to meter cool and more combustible air at extremely high pressure to insert a precise dosage of fuel individually into each cylinder's combustion chamber. Other direct-injection systems increase power, but Ford succeeded in coordinating the more efficient fuel-burning to aid power and fuel economy and to lower emissions. “We promised a 20% increase in fuel economy, and we delivered a 25% improvement,” says Brett Hinds, advanced engineering design and development manager of the EcoBoost. “And we also achieved a 15% reduction in emissions.” “Fuel economy is one of [farmers'] top needs,” says F-150 marketing manager Mark Grueber. “In our tests, farmers have praised the EcoBoost's low-end torque but also have been pleased to get 17 or 18 mpg and over 20 on the highway.” By 2012, Ford expects to produce 750,000 EcoBoost engines in the U.S. and 1.3 million of them globally. The F-150 EcoBoost will reach showrooms late in 2010. Ford thinks farmers will appreciate the EcoBoost's durability and reliability. And once the crops are in, that EcoBoost engine might come in handy for drag racing. |
Guess Who's Back?
Great find, I read somewhere this engine won't be going into the Mustang as the performance is too close to the new Coyote V8. It's a good issue for Ford to have, but it makes you wonder what it would have been like in the Falcon (not that many I6T drivers would care).
The 18th Letter |
Render unto Caesar
Nice write up, was looking forward to the introduction of the Ecoboost V6 in the Falcon to see how it fared against the I6T.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
#4 | |||
Ich bin ein auslander
Unlikely to happen as falcon is getting the ecoboost 4, which I think will surprise many.
Growing old is compulsory, growing up is optional! |
#5 | ||||
#6 | |||
Render unto Caesar
Myself as well. Particularly when you remember both the ecoboost 4 and V6 run pretty conservative boost levels. Once people start dialling up more boost (more on the V6 rather than 4) you should see some impressive power figures.
Personally I would not be at all surprised if the EB4 puts up a good show against the 4L I6 in NA form.
#8 | |||
Getting it done.....
Good find. Its still early days in the grand scope of things for ecoboost. In years to come Ford will only keep improving the engines as well. Certainly in a heavy truck they are aiming for about 520nm of torque according to what the ford guys quoted. That is certainly going to take down the current 5.4 V8 because it makes about 500nm tops in the F series and obviusly the torque curve is much flatter in the 3.5T V6.
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
Although the ecoboost 4 sounds like a great engine it's gonna play hell with resale values. I'm assuming huge amounts will be sold with this engine but younger people will not be able to drive them and will go else where due to either probationary licenses or insurance imo
Wouldn't mind getting my hands on the Ecoboost V6 though ![]()
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
#10 | ||||
#11 | ||||
Nutty Professor
Back on topic, I heard a rumor that there is an Ecoboost 5.0L V8 on the edge of the foreseeable future for FPV. Can anyone provide any more information on this?
#12 | |||
Pretty sure probationary drivers can drive the VW Golf GT which is a supercharged and turbocharged 1.4L.
My metal blog http://metaldadaustralia.blogspot.com.au/ |
#13 | |||
Render unto Caesar
Some facts on Vicroads stance on P-platers and turbo cars.
http://www.arrivealive.vic.gov.au/in...ply_if_yo.html Quote:
#14 | |||
#15 | |||
Thailand Specials
The chances of getting one are slim. I was going to apply to drive a TT Toyota Aristo because it actually fell under 4 doors, under 125Kw/Tonne (124 lol) and not considered a "sports car" but it has the 2JZ-GTE engine anyway which is in the JZA80 Toyota Supra, but I looked at the Form and thought that a private seller wouldn't waste their time or give out all the details on their car. I'd guess that might be a loophole if you can find powerful cars like these that are 4 door. I'm guessing the people in charge of VicRoad's exemptions would look at the name "Toyota Aristo" and think grandpas car. I know that same engine in the Supra is capable of doing 0-100km/h in 5.1 seconds from factory and doing a 13.7 second quarter mile, probably a bit slower for the Aristo because its a heavier car and luxury orientated instead of sport, but still it would be quick. It puts you back at square one anyways because its still giving you a slight chance of driving something fairly powerful? Last edited by Franco Cozzo; 29-09-2009 at 12:33 PM. |
#16 | ||||
Force Fed Fords
Mate, that's what you get when people who are chauffer driven everywhere make the rules. It's also why the brightest people in the land tend not to enter politics.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
#17 | |||
My 18 year old brother can drive my parents BF XR6 N/A but his dream car is an old HZ Premier with a 253 and we all know how gutless that is, and yet it is banned..........
#18 | |||
Thailand Specials
#19 | ||
the problem with power to weight is it doesn't take in to consideration efficiency or other factors. EG, an electric car could weight 1000kg, and be powered by a 100kw elec motor, which would be similar in performance to a 300kw petrol powered car, also weighing 1000kg.
They could just ban vehicles with a certain acceleration... but it would be silly to test people's cars which may have been modified, hammering every car to see if it doesn't do a certain acceleration time. I have an idea... how about put more cops on the road, and let people drive whatever, but if someone is being an idiot on the road and/or speeding, then give them a ticket. It's a novel idea I know... and what am I thinking? |
#20 | ||||
Force Fed Fords
![]() Actually mate, I was bored a couple of weeks ago so flew to Seattle, hired a car and drove around Everitt to check the 787 via the factory tour. I was pulled over twice in 3 days because I was a single male driving a car. The first trooper was looking around the car for any drug paraphernalia but after seeing my licence (Australian licence, obviously a tourist) became alot more relaxed. The second trooper noticed my accent and asked where I was from (no, not from England) and was more relaxed as well. I asked why I was being pulled over on account of being pulled over 2 days earlier, and he admitted it was because a lot of young-ish males drive alone when looking for drugs. Anyway, they profile people in the USA and it's a damn good thing. They also give tickets if you speed, but that is some serious speeding before they'll stop you. They'll pull you over instantly if you tailgate someone, or if you undertake a vehicle. Oh, and you can turn right on the red unless sign posted (equivalent to turning left on the red here).
#21 | |||
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
#22 | |||
#23 | |||
Peter Car
#24 | |||
Peter Car
I'd love to know what happens when you max out the injectors in a DI engine, is is possible to get bigger ones? |
#25 | |||
![]() Join Date: Dec 2006
I'm pretty sure there is a lot of other stupidity here in the name of road safety. Anyway, back to the topic, Ecoboost (turbocharging) was always going to work when applied and sorted. When you think of the effeciency of a b-double truck, typically using a 15 litre engine of about 550hp using fuel at the rate of 50 to 60l/per 100 km which is a lot, but in doing so shifting 68 tons or the equivalent of 40 Falcons. Whereas (someone please correct my maths if I'm wrong) 40 falcons at 10 per 100 (and few get that) would use 400 litres to do the same. Or to get the same effeciency a sinlgle 1700kg Falcon would need to be using fuel at the rate of 1.9 litres per 100 to be as efficient as a typical b-double truck. Turbo charging has seen massive imporvements in engine efficency which we mostly see as 800hp F6's. But working it back the other way boost creating power on demand, small capacity creating fuel efficiency at the lights and coasting along. This ecoboost is the beginng of what we will see IMHO. Me I'm just waiting for the Ecoboost Coyote V8. 500kw anyone.
Oooh baby living in Miami....
#26 | |||
Thailand Specials
#27 | ||
yep and the b dubs do it with the aerodynamics of a very large brick.
