01-07-2011, 01:40 PM | #1 | ||
FordTarius
Hi all,
Two questions folks - all related to leaking power steering racks and hose on AU3. a) Whats the trick to getting the HP hose out from the bottom (rack-end side). I am not getting enough swing for the spanner to loosen the nut. The hose right next to it doesn't help things either ! 2) Pedders wan't ~ $750 (incl w/alignment) to replace the PS rack. It sounds high but I wanted to know your opinions on the going rate for this sorta work. Any (cheaper) alternatives for Brissie would also be appreciated. thks !!!! Ash |
01-07-2011, 02:29 PM | #2 | ||
Flairs - Truckers Delight
Hi Ash
What rough location of brissie are you at? A. I can't remember. Just get an enzed dude out and he'll do a replacement hose fitted for about $100, if it makes your car undriveable 2. LOL 750 for a rack Any servo mechanic will be able to replace your rack with a reco swapover one for about the $350 mark, then just pop down to your local indepenant tyre shop for a $39 wheel alignment.
01-07-2011, 02:57 PM | #3 | ||
FordTarius
Western surburbs - Indro
a) I thought Enzed didn't do hoses attached to cars . I have the replacement hose anyway - (repco aftermarket). Can probably get them to fix up the original hose once I find a way to get it off :-( b) Yeah - I knew that $750 couldn't be 'right' thanks -ash |
01-07-2011, 10:05 PM | #4 | ||
Crowsfoot flare wrench or sensor socket like this helps.
regards Blue |
03-07-2011, 12:12 PM | #5 | ||||
ive been quoted something like 520 for a reco and wheel alignment at an independent shop in my area and even that sounds like a rip off....still getting around to finding the cheapest place as ive read everywhere that recos are 350 on average
Daily: 2003 BA Fairmont Ghia - Mercury Silver | Sunroof | Tint | XR6T 3.46 LSD Project: 2001 AU II Fairmont Silhouette | Optioned 17" Tickford wheels + Sports suspension | Tint Weekender: 1989 NA II Fairlane - Rosewood | Standard (with functioning SLS!) Quote:
03-07-2011, 10:21 PM | #6 | ||
I'm pretty sure it was enzed that my brother got out one boxing day to replace the HP PS hose on his old VL
04-07-2011, 01:21 PM | #7 | ||
FordTarius
thanks - had to SOS a mechanic mate who had the tools that `aussieblue` mentioned.
Job done - leak monitoring now on... |
05-07-2011, 09:43 PM | #8 | |||
Enzed will do most hoses on cars but no braided brake lines as they are not ADR approved and they can get in deep **** for doing them. Most AU's have a rack weep or very minor leak. Not worth fixing till it starts dripping on your driveway or your having other issues too.
AU XLS. |
