Old 18-07-2011, 01:59 PM   #1
midgetyone
Default AU3 XR6 Fuel injector removal
Hi all,
I was planning on removing the injectors in my AU3 Xr6 to have them ultrasonically cleaned and I thought I ask for any handy advice (as I have not removed them before).
Few questions as well
-Easiest to remove throttle body first?
-Is there enough slack in the hoses to the rail to not need to disconnect them?
-Injectors just sit in with o-ring seal and should basically pop out once fuel rail is unbolted?
-Should I sit my old EL injectors (if they fit) back in while the others are out to prevent any foreign matter getting in?
-Any bleeding/priming work needed after re-installation?
-Any concerns/nasty surprises?
Chris
____________________
01 AU III XR6 Venom Red
Pacemaker 4499 with 200cpsi cat & 2 1/2' Sports exhaust
SS Induction Kit
midgetyone is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2011, 02:20 PM   #2
StealthAu
Default Re: AU3 XR6 Fuel injector removal
From memory it is pretty straight forward, remove intake pipe, unbolt throttle body and move out of the way (no need to remove throttle/cruise cable/wires). I don't recall having to remove hoses from the rail to swap injectors, I wouldn't fit other injectors while yours are being cleaned, just over everything up with some clean rags. Reinstalling is just as straight forward, no priming or anything.
Old 19-07-2011, 10:53 AM   #3
midgetyone
Cool thanks
Chris
SS Induction Kit
Old 19-07-2011, 02:13 PM   #4
FGII-XR6
FGII-XR6's Avatar
there are some good on car injector cleaners about now this is not stuff they put in your tank they hook a container up in place of your fuel line and run the car off it. I had it done by my mechanic with the throtle body cleaner as well. did a great job and didn't need to remove the injectors. you could eat your dinner of the throtle body
[SIGPIC][/SIGPIC]
Rides:
Old 19-07-2011, 03:48 PM   #5
midgetyone
Well it's $180 to get them reco'd or $180 for an on board carbon flush so I kinda feel that it would be best to do the reco at least then I can confirm a good spray pattern. Often wondered how the affective the carbon flushes are though? Any before after stories?
Chris
SS Induction Kit
Old 19-07-2011, 04:36 PM   #6
FGII-XR6
FGII-XR6's Avatar
mine cost me $85 with the throtle body clean and the result was well worth the money the car had better economy was better on the road idled better
[SIGPIC][/SIGPIC]
Rides:
Old 08-02-2015, 01:01 PM   #7
donisbest
I removed the fuel rail and injectors popped out of cylinder head, but can't get them out of fuel rail. Seem to be stuck in there???
Any answers there as to why or how to remove them without doing damage.
thanks.
donisbest is offline   Reply With Quote Multi-Quote with this Post
