04-08-2011, 09:25 PM | #1 | ||
ive found a manual EL wagon,
and im wondering how much of it would fit an AU sedan?? all replies appreciated, i really want mine manual!! cheers |
04-08-2011, 09:39 PM | #2 | ||
yep just need to change bell housing as el to au are diffrent all the rest will bolt in no probs , not a small job though
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
05-08-2011, 08:05 AM | #3 | ||
RIP...
The extension housing is longer on an AU box.
. Oval Everywhere... |
05-08-2011, 11:23 AM | #4 | ||||
Back to Le Frenchy
05-08-2011, 11:58 AM | #5 | ||||
Petro-sexual
09-08-2011, 10:44 PM | #6 | ||
hey guys, does the ECU have to be changed? will an ED ecu work?? (im assuming NO but thought id ask lol)
and how would we go about pedal box, could i attach a third pedal or would it be reccomended to change the entire pedal box? thanks! |
10-08-2011, 09:23 AM | #7 | ||
I would change the whole box... im keen to know how this goes, keep me posted.
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
10-08-2011, 09:44 AM | #8 | ||
Silky Smoothe
Whole pedal box would need to be changed, otherwise you'll have no gap between the oversized brake (auto) to the smaller brake (manual.)
[R1XSTA] - 2003 BA XR6; Blood orange. Sports Leather. -SOLD - MY12 Holden Cruze SRI-V, 6spd man, sunroof, leather. - SOLD - 2006 Ford Territory Turbo; Silhoutte, Leather, Plazmaman CAI. |
10-08-2011, 11:10 AM | #9 | ||||
Back to Le Frenchy
10-08-2011, 11:15 AM | #11 | ||
ok sweet, i keep finding kits/parts for older fords, thats all lol. i was on my tippy toes about to buy one (then declare myself broke lol) but i think ill save for a bit longer...hopefully a week or two from now
10-08-2011, 12:34 PM | #12 | |||
Whats the Resistor trick??? |
25-09-2011, 10:16 AM | #13 | ||
so what exactly is the resistor trick to let the ecu run manual?
what will the car perform like if i use the auto ecu? anybody know what the j3 chip for manual conversion is all about? ANNNND will the computer from an EL manual work on the au?? thanks again guys!! - didnt want to start another topic for this |
25-09-2011, 11:50 AM | #14 | ||
not only can you use nothing but an AU ECU you can't swap between series 1 and series 2 / 3.
a j3 chip is a device that plugs into the bottom of the ECU to change it's settings your best option is to watch ebay for a cheap ECU they normally go fairly cheap
[SIGPIC][/SIGPIC]
25-09-2011, 12:11 PM | #15 | ||
The resistor just stops the fans running full blast non stop. I ran the auto pcm in mine for a few weeks and it stalled maybe 6 times when slowing down.
AU XLS. |
25-09-2011, 01:11 PM | #16 | |||
[SIGPIC][/SIGPIC]
25-09-2011, 01:51 PM | #17 | |||
good to know it is driveable though. |
25-09-2011, 03:20 PM | #18 | ||
Bugger!
The resistor trick is the practice of putting a 1/4 watt, 1.5 Kohm resistor across the two wires out of the ECU which run to the selector switch. This tells the ECU that the gearbox is in Neutral. It's not for the fans, it's for the idle control primarily. Without it, the engine will idle at 1500 RPM unless you unplug the idle solenoid, which often means it won't idle cold at all.
From memory, and it's been a while, I'm sure the Smartshield wasn't introduced until serII AUs. I know for a fact the serI computers are compatible with EFs, I have one in mine as we speak.
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
25-09-2011, 09:16 PM | #19 | ||
Mine didnt idle high, it was just irratic and low.
Running an auto PCM in a manual car will put the fans on all the time. The PCM doesnt see the gearbox anymore so it hits the fans as a safe gaurd for overheating the tranny oil. The way i see jobs like this is do it once, do it right or dont do it.
AU XLS. |
26-09-2011, 08:08 AM | #20 | |||
a friend of mine converted his vt commonwhore to manual and said he paid an auto elec to do some sort of wiring stuff to the ecu and it performs likes a proper manual, cost only $120, would that be the same thing? |
26-09-2011, 11:06 PM | #21 | ||
Bugger!
Yeah, it performs like a manual. Basically it tells the computer the gearbox is in neutral, so it disregards the control sets for the auto. Nothing wrong with doing it that way, I've had the same auto computer in two different cars over the last ten years set up like that and it's been fine. Most likely your mate paid the sparky to do just that. I specialise more in Fords than Holdens, but can't see it'd be any different.
27-09-2011, 02:17 PM | #22 | |||
[SIGPIC][/SIGPIC]
