Old 20-09-2011, 05:11 PM   #1
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Default Setup for ED
Gday,
I am a recent drag racing addict, thank the FF nats for that and Im after some advice on setting my car up to maximise its grip and launch.
What are some decent components, setups and theories to get it off the line? I haven't had traction issues but it hasn't been to the track with the C4 and 3000 convertor, which I'm a little worried might struggle as now ill actually leave the line on boost.
Before I go adding more HP I wanted to make sure it can put this power down first.
It uses a 255/60/15 MT drag radial, 3.27 Diff and has approx 530hp and usually traps at 126-7mph with the BTR in it.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 09:31 PM   #2
dieseltrain79
Default Re: Setup for ED
Tyre pressures with the Drag Radials will be critical . Some say start them high and work your way down to find the sweet spot on them .
Otherwise its trial and error my friend Good luck
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 09:52 PM   #3
Psi-Pop
Psi-Pop's Avatar
I had best luck at 20psi at Heathcote, I'm hunting around looking for a set of 90/10's and something suitable for the rear.
8.9x@160mph+
Old 21-09-2011, 12:10 PM   #4
dieseltrain79
90/1-'s are good , but can sometimes be too light ont he front end . When you launch they can just throw the front up too quickly and rebound alot faster taking all that weight thats been thrown rearward, back to the front again .
80/20's are good compromise .
Old 21-09-2011, 12:26 PM   #5
FreddyDUZ747
FreddyDUZ747's Avatar
You running a two stage boost controller?
Keep the suspension stock,Pop and just work on it each meating with all changes logged.I think you wont have much drama hooking up once the tyre heat and psi are established.
Whats the rear end look like underneath?
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
