10-11-2012, 12:28 AM | #1 | ||
Hi All,
I have noticed of late that there is a lot of steering wheel vibration for about 10 minutes of driving before it goes away. I have recently had a wheel allignment, balance, rotation etc. However it was there prior also. Never really though much of it as my wife normally drives the car. It is only when cold, so say it was left over night and driven the next day. Any thoughts or experinces similar guys?
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please! |
10-11-2012, 11:03 AM | #2 | |||
10-11-2012, 01:07 PM | #3 | ||
What tyre pressures are you running?
apstar |
10-11-2012, 02:38 PM | #4 | ||
39psi front and rear, normally drive with a full load i.e 5 passengers...
11-11-2012, 02:33 AM | #5 | ||
it occurs to me seeing as the tyres have been rotated, it is unlikely to be a tyre problem..................unless
a. the tyres where`nt rotated b. you have 2 tyre`s that could be dodgey........longshot, might pay to look at tyres very carefully, flat spots/delamination? c. the balancing machine is buggered or the apprentice was doing it? d. there is looseness in the steering gear or suspension somewhere,wheel bearing? any looseness in suspension or steering gear,hub can exaggerate the smallest out of balance problem. |
11-11-2012, 09:43 AM | #6 | ||
Check the power steering fluid level. If OK, have the fluid changed and the pump checked.
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel. |
11-11-2012, 11:10 AM | #7 | ||
Driver Returns On Foot
rotors not warped?
02-03-2013, 09:28 PM | #8 | |||
By putting that wheel on the rear has now reduced the severity, however I will be taking it to Chris Neil (Wheel Revolution) to correct it. Watch this space!
14-07-2013, 03:34 PM | #9 | |||
I had a good recommendation on the VW Forum that I am also on for the following; Ricks Wheel Alignment Albion P: 07 3852 2737. They did my Jetta and the Mondeo. Rick found one of the problem areas that I described above. He found that the Steering Rack Ends require replacing (under warranty) as there is excessive movement. I am getting this done next month when I have my 2yr service. They once again found the buckle in the rear wheel as it could not be balanced true. They recommended the following company; The Wheel Workshop 1/16 Jobson St ALBION P: 07 3862 4587 Sam fitted me in straight away and fixed the buckle (slight buckle). So the car is almost back to driving normally again... As I said before, watch this space - the issue WILL be resolved!!!
15-08-2013, 10:00 PM | #10 | ||
Ok, so took the Mondeo in for its 2yr / 30,000kms service.
Props to Jason and the guys at Q Ford Browns Plains. They did a great job on the service and actioned all the request items that I had outlined in conjunction with the service. Update of ECU and PowerShift PCM where done and now is driving super smooth! They even replaced the Interior Pollen Filter (as per the "A" scheduled Service) some people have mentioned that this does not get attended to as part of the service... As for the steering issue, I am still not convinced! I will monitor for the coming days and will action further as required. So once again - watch this space...
13-09-2013, 01:57 PM | #11 | ||
Ok, so just changed the tyres. I replaced the OEM Goodyear EfficientGrip 215/50R17 with a 225/50R17 Bridgestone Turanza T001 (made in Japan). The car is now wonderful again, no more wobble in the steering wheel / tramlining or tracking issues!!! A little more than I wanted to pay, however Goodyear / Dunlop did not have stocks of the tryes I wanted in conjunction with there current promotion (Buy 3 Get 1 Free).
11-04-2015, 08:54 PM | #12 | ||
I just found this thread looking for any issues with OEM tyres.
I've had a wobble at highway speeds since I bought it last June. I drive 20km of motorway each way to work and its enough for the sun visor to wobble when I have it down. 80 or under you can't notice it. I've rotated all tyres to the spare without any difference. Had a balance and rotation done by KTAS before christmas without any difference. Last service at Metro Ford I asked them to investigate and they went to a lot of trouble to balance the tyres, even rotated some on the rims. As soon as I got on the motorway I could tell it was the same. These are 215/55-16 OEM goodyears. 3 of them are dated 2011, the other 2013 so some of them may have been on since new, nearly 80,000km but they are not worn yet and have not changed much in the 22000k since I bought it. I've been tossing up just getting new tyres all round. I had a similar issue with our AUIII wagon years ago, fitted new bridgestones and all the issues went away. After reading this thread it's helped make my mind up so thanks!
2016 Kuga Trend TDCi |
