Dee
Hey guys, I have a problem. There is bubbles in the header tank, my first thought was blown head gasket but there is no other signs just the bubbles, there was a loss of water, about a quarter in a few days but its been three weeks and no more loss of water, any ideas??
same thing happened to me
it bubbles and rises up and down well mine did consulted the mech who advised recore radiator, flush cooling system, new temp sensor etc etc about $500 went home waited till the next morning and topped up the coolant and all good hope this helps cheers gra |
sound like a head gasket but just keep an eye on it and see what happens before you chuck money at it.
if it ends up being a head gasket it's better to buy a good low K engine you can get an engine with under 100K for a few hundred if you look around . a lot of wreckers have them coming out of their ears as they are so reliable they don't sell many
[SIGPIC][/SIGPIC]
Dee
Thanks, it's been bubbling since I bought it a few months ago topped it up when needed but bubbles still there...
Would anything else cause the bubbles apart from head gasket? There's no smoke, no power loss or anything else like that. |
get a mechanic to do a carbon monoxide test, they put a test tube with chemicals in the header tank and if it changes colour then its a head gasket or cracked head/block. takes all of 5 mins.
#6 | |||
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Dee
Awesome thanks, I'll do that tomorrow
it's sad there are mechanics around who know this little. if the gasket is blown in a way that allow oil into the coolant then you will get what he describes but if there is damage in the gasket only between the cylinder and a water jacket then you will get bubbles but no frothy white on top. the frothy whit stuff is an emulsion of water and oil
[SIGPIC][/SIGPIC]
Hence why the carbon monoxide test is a good test to get done as well when trubleshooting. As mentioned earlier.
2 users like this post: |
Au Falcon = Mr Reliable
Aufordchick, sorry for the questions - How hot was the motor getting when it was dumping water? Did you find out where it was leaking from? How old / fresh is the coolant? Old & over diluted coolant will froth / bubble up when near boiling point, but as said above, i would be inclined to go to a radiator specialist asap to get the gas test done if you cannot find the source of the water leak.
p,s - is it me but i get the feeling the mechanic could have done more to verify the problem? cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 27-04-2013 at 11:06 AM. |
#12 | ||
5.6L x 2 pilot
Not just you Maka. I would have thought he would be interested in the business - clearly not.
Stu
Dee
The coolant is only a month old, I have no idea where it's leaking, sometimes it leaks but other times it doesn't, topped it up 3 days ago and hasn't moved. The hottest the car gets is on the N. when He mentioned the frothy white stuff I said there was no water in the oil but he said the frothy white stuff is caused by the carbon monoxide
#14 | ||
Dee
I'll definitely be taking it to the radiator place on Monday, hopefully its not a blown head gasket
#15 | ||
Dee
I just read that a faulty thermostat or stuffed radiator cap can cause bubbles in the tank, I'm gonna replace both of these today and see what happens, fingers crossed it fixes it!
#16 | ||
Dee
Just had a good look at it while the car was going and it looks like the bubbles are caused from the water going into there really fast, water is also spraying up onto the top of the tank. Also there's been water coming out the overflow pipe so I'm pretty sure that's where the water is 'leaking' from, there's a coolant stain there and has been for a while just didn't know for sure if it was coming from there but when I looked just before it was wet, anyone know why the water would be getting pushed out there?
#17 | |||
[SIGPIC][/SIGPIC]
#18 | ||
OWN THE ROAD
Head gasket gone or warped head
TS50 T3 BUILD NO. 97 -- BLUEPRINT, AUTO, BREMBO BRAKES, PREMIUM SOUND EFII XR8 -- LEMANS RED, 5SP MANUAL, RDA BRAKE BRAKE ROTORS WITH BREMBO PADS, PREMIUM SOUND, CUSTOM LEATHER INTERIOR SHOPPING TROLLEY - FG MKII G6E WORK HORSE - P250 |
#19 | ||
Auto Nerd
Like others have said a hyro carbon test would confirm a head gasket issue.
But, if the system is not pressurising then the boiling point will drop. The cap is rated at 120kpa, which is about 17psi. For every 1psi, the boiling point is raised by 2 degrees. Potentially, you can have a system that reaches its boiling point 34 degrees earlier than it should. When the thermostat is rated at 92 degrees, these symptoms are plausible. Can you feel some pressure in the top hose at running temp? Hopefully it will just be a cap and thermostat. |
#20 | ||
Dee
Yeah I'm definatly going to get the test done, just hoping the cause of the bubbles is something simple. How do I check the pressure? Do I squeeze the hose?
#21 | ||
Yeah ... squeeze the top hose when it is up to temp.
Another thing I had was a small crack in the header tank near one of the front smaller hoses on my AU ... and just replaced it with a B-series header tank from a wrecker (near new for like $40
#22 | ||
Dee
Ok cool I'll do that in the morn, so what's good, if there's pressure or no pressure? I have no idea about cooling systems lol
#23 | |||
![]() I'm thinking gasket issue myself but it really needs further investigation before the small issue turns into a REAL EXPENSIVE 1 IMO. |
#24 | ||
Dee
Haha, there's a radiator place here I'm gonna see on Monday. I did squeeze the hoses today while it was running and they were pretty easy to squeeze in, I'm gathering that's not normal if its supposed to be pressurized!?
#25 | ||
5.6L x 2 pilot
Correct. Hoses should feel tight when up to full temp/pressure.
Good luck and hoping it is not too bad for you. Cheers Stu
#27 | |||
Auto Nerd
Just so you don't get told BS on Monday, A radiator cap and thermostat should cost no more than $40. Roughly $12 for a cap, $14 for a thermo, $10 for the o ring and gasket and around 500ml of coolant to top off. With the test, you would be looking for the presence of hydro carbons (unburnt fuel) or carbon monoxide (partially burnt fuel) in the coolant tank. There is only one way in and that is via a head gasket that is not doing its job. |
#28 | ||
Dee
Yeah will definitely replace the cap and thermostat first before I get it tested, also is it normal for the big pipe that comes from the water pump to be soft in places and really hard in places?
#29 | ||
Dee
Its like there's metal in the pipe in certain places, its a different kinda hose, all the other hoses are normal but this one has grooves in it
#30 | ||
Auto Nerd
There is a metal skeleton inside the hose from the water pump to the radiator (bottom hose). It is there to stop the hose from collapsing under high rpm - not that I think that will ever happen with our plain 6's!
What you dont want is for the hose to feel 'crunchy'. This would suggest the metal is corroded and time to change it out. When the system is working correctly the top hose should be hotter than the bottom. I have a non contact thermometer now, but I used to just use the wife's thermometer that she used to stick in the Sunday roast - got into a bit of trouble for that... ![]() |
3 users like this post: |
