I have bought a horn steering wheel unit from the wreckers and want to test it with the multimeter before I deliver it to my daughter in Broome. How do I go about it without blowing the airbag?
Got Ghia?
Set your multimeter to ohm's (or continuity tester if it has it) and put it across the horn plug, shouldn't get any reading until you press the horn pads.
Just don't get the airbag plug by mistake as the multimeter uses a 9v battery to test continuity and is enough to set it off!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
I presume the horn plug is the one with the black and white wires?
Got Ghia?
IIRC the air bag plug goes into the middle of the air bag and the horn is a connector up the top
Thanks guys, I got it right.
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Group hug
![]() UK
