An easy one for someone,
Is dot 4 ok for use on an 07 LT TDCI? Low level light comes on occasionally. Pads are down a bit but not done yet so I thought a little top up would suffice. Cheers |
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
Recommended fluid is Super DOT4 to ESD-M6C57-A Specification.
Cheers Russ
Observatio Facta Rotae
Unfortunately, ESD-M6C57-A spec brake fluid is very difficult, if not impossible, to come across in Australia.
The post below is well worth a read: http://www.fordforums.com.au/showthread.php?t=11370556 |
Surely Ford stock it, if that is what they recommend?
2018 Ford Focus RS |
Not according to the above link I posted. The guy had to source it from the UK. Try a Google search for "ESD-M6C57-A" in Australian sites only - not much comes up at all.
Ok, got that, call me **** but you have a 07 model and you are topping up? I never let brake fluid go past 2 years before a complete flush, maybe just the way I am, never in a position to need to top through pad wear.
cant believe that word is in the swear filter, its in the dictionary!
Yep, have an 07 and am topping up.
Thankyou for your insightful comments ![]() |
