13-07-2014, 06:01 PM | #1 | ||
Winding roads please
Has anyone removed , turned off or blocked off the sound symposer. I'm sick of hearing it and want to try it out.
HURRY UP WEEKEND DRIVE |
14-07-2014, 08:04 AM | #2 | ||
Chairman & Administrator
You can't turn it off - it is a mechanical device.
You could (potentially) remove or block the tube however. Cheers Russ
Observatio Facta Rotae
14-07-2014, 02:59 PM | #3 | ||
You can just unplug it.. I do it sometimes as I get tired of the sound
2013 Ford Focus ST
14-07-2014, 03:49 PM | #4 | ||
Where do you unplug it from? Hose coming out from under windscreen in engine bay?
14-07-2014, 05:04 PM | #5 | ||
No the electrical plug on the side of the symposer unit, which is at the other end of where the hose which connects in under the windscreen goes. It might be partially obscured from sight by the intake tube
2013 Ford Focus ST
14-07-2014, 06:37 PM | #6 | ||
Im sure Ford can just turn it off
Mine stopped working and required an update to fix
GH Sigma EFI 351, 394whp @6500rpm |
15-07-2014, 11:16 AM | #7 | ||
Or you can unplug it for free.
But yes, the sound symposer is electrically operated and can be turned off. A lot of people get this done in their remaps.
2013 Ford Focus ST
15-07-2014, 07:32 PM | #8 | ||
I had mine tuned out with a new ECU file ages ago, you can buy manifold blanking plates, or you could remove the hose from the firewall plastic thing that I remove every track day to get air flowing through the engine bay, and then plug the hole with a grommet so engine bay air doesn't leak through when interior air flow is outside air.
2018 Ford Focus RS |
17-07-2014, 11:58 AM | #9 | ||
I have removed my unit all together and purchased a block plate from a US company called BREEDT. Definitely worth it if you have an intake and exhaust as it removes the in cabin noise of the symposer.....but that is just my objective opinion.( i just found it too loud under accel)
19-07-2014, 05:15 PM | #11 | ||
Just blocked off the sound symposer hose outlet next to the battery with a door stop of all things... test drove.... beautiful. Nice n quiet.. will still look to completely remove the setupuploadfromtaptalk1405750824684.jpg
19-07-2014, 05:51 PM | #12 | ||
Have to love Australian innovation
19-07-2014, 07:05 PM | #14 | ||
genius
