Old 12-12-2014, 10:43 PM   #1
xpunxnotdeadx
Smile Hey guys need help
Got a ford festiva 1999 1.5L replaced the tappets and cleaned the engine heads
Changed oil filter fuel filter drove down road and car came to a holt oil light
Came on towed car home cleaned out sump was filthy as cleaned it replaced and flushed turned the key engine won't turn over but sounds like wants to start restarted ecu and checked battery help have checked relay too any ideas thankyou
xpunxnotdeadx is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2014, 11:47 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Hey guys need help
I know this type of car and its mazda engine
http://www.fordforums.com.au/showthread.php?t=11426230
please confirm
it is turning over but wont start
or engine will not rotate a crank revolution
some history please
is this a poorly serviced or high km motor
maybe
faulty oil warning light
oil pump failure=ceased engine
while you had the sump off did
you have time to check a main bearing cap or conrod bearing
My car goes Brumm Brumm
Old 13-12-2014, 12:12 AM   #3
xpunxnotdeadx
The engine cranks Theres power at the distributor cap
Low kms but questionable condition as the oil pick up was absolutely filthy engine not ceased
Thanks
Old 13-12-2014, 08:03 AM   #4
dirty hands
Over Thinker
good that it turns over and there is spark
so ecu is working
are all the fuses ok
I would look at fuel delivery next
maybe a fuel filter
check if fuel is getting to the injectors
Old 13-12-2014, 03:58 PM   #5
xpunxnotdeadx
Smile Re: Hey guys need help
Heyo fuel is getting to the injectors just no spark to the spark plugs :(
Old 13-12-2014, 05:02 PM   #6
Pursya
Leads?
Is there a spark at the end of each lead?
Pretty easy to check. If no, and there's a distributor involved maybe there's an issue with the leads or a cracked distributor.
Only guessing.
Pursya is offline   Reply With Quote Multi-Quote with this Post
