Old 16-01-2015, 12:34 PM   #1
FTe001
Default Au 2/3 Premium sound
Hi all,
The Premium sound in my Au3 everything works good but no sub
Iv tried replacing the sub and it's not that
Any help is greatly appreciated
T3 TS50 #001
T3 TE50 #063
T3 TE50 #061
BF COBRA #144
FG RSPEC #239
FTe001 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2015, 03:41 PM   #2
Dauphin
Irregular member
Dauphin's Avatar
Default Re: Au 2/3 Premium sound
Behind the driver's side trim in the boot is the amp for the sub. Check that?
Old 16-01-2015, 08:17 PM   #3
FTe001
Yeah checked that, the fuse is good and all wiring apears to be fine
T3 TS50 #001
T3 TE50 #063
T3 TE50 #061
BF COBRA #144
FG RSPEC #239
Old 17-01-2015, 02:30 AM   #4
justlikemusic
They run a weird amp with odd coloured wires and no markings if I recall correctly. It would be hard to test if that amp is working or not. It could also be the head unit. You might be able to find which wires go to the amp and try to put an external stereo source into those to test the amp/cancel out the head unit but that's as far as my knowledge goes with the stock systems. I only have experience with removing them
'01 AUII XR8 Ute - "200kW" - As good as burning money.
justlikemusic is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2015, 11:37 AM   #5
Spurious
The best thing you can do with ANY stock system!
Spurious is offline   Reply With Quote Multi-Quote with this Post
