AU XR8 Owner
Howdy all
I have managed to pickup a set of S2 front brakes and associated bits for my S1.5 XR8 but am not sure if I need the master cylinder or not. I have the dual booster coming so that side of it's sorted, its just if there is any difference in valving between the S1/1.5 master and the S2. Anyone know? Cheers Bruce
My Current Stock of Fords: 1994 ED Wagon retrofitted with '98 EL equipment 2000 AU1.5 XR8 in Winter White - Ex Police |
![]() Join Date: Nov 2011
Don't believe the series 2 master or booster is needed but will need s2 sway bar, links, and brackets to go with s2 lower arms with the brake setup.
AU XR8 Owner
Thanks PJ, will cancel the master. I have everything else as per the thread here so should be good to go
Spanner Thrower
S1 and S2 Boosters are different. you would have to drill the firewall to make the S2 booster fit. (S1 has a 2 bolt, S2 onwards has a 3 bolt.)
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
