Old 01-08-2017, 11:06 AM   #1
_Ben
_Ben's Avatar
Default AU2 XR6 VCT takes ~5-10 seconds of cranking to start
Hey guys,
Got an AU XR6 VCT ute with 265k ks on it, 5 speed manual (if it makes a difference) that consistently takes ages to start
This is what happens every time
- Crank for a second or two
- it splutters as it gets fuel
- not enough fuel to run, if you stop cranking it instantly stalls
- keep cranking and it'll jump to life after ~5 seconds
Its running a full exhaust (extractors, high flow cat (has a small leak around a weld), one big muffler), has a pod on the standard intake piping. I always run 98 in it, and I give it a flogging :P
So far I've done
- Replace fuel filter
- New plugs
- New leads + coilpack
- Service
- Cleaned the throttle body / intake
When its cold it seems to bunnyhop a little bit (especially while turning), but this seems to be better since I did the coilpack and leads. It did also have a misfire when going full blast in 1st sometimes, but again that seems to be fixed
Heres a video of it
https://www.youtube.com/watch?v=MxyBpOIvHwg
My thoughts are now that it could be fuel pump?
Crappy 01 AU Ute - Braaaaap
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2017, 11:50 AM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: AU2 XR6 VCT takes ~5-10 seconds of cranking to start
Is the fuel pump priming when turning the key? Anyway, the pump will prime & can still be stuffed lol.
If its cutting out around roundabouts or flooring it, the fuel pump is not delivering the appropriate fuel flow & is worn out. Probably need to replace it, good luck!
Edit, check to make sure your inlet manifold bolts are tight & the gasket is not leaking.
cheers, Maka
