04-11-2018, 10:37 AM | #1 | ||
Previously TUNGA
I have to remove my tub liner to check the fuel pump sender unit as is shows empty when full , The bolts holding the sport bar on keep spinning
and won't undo , any clues would be great as car requires a RWC and can't get it with a dodgy fuel gauge
AU2 XR8 Pursuit Ute Liquid Silver |
04-11-2018, 11:31 AM | #2 | ||
#neuteredlyfe
The nuts used to hold the sports bar are not captive. You will need to get a spanner up under the inner guards to hold the nut. You will also need to do this for the nuts at the front of the tub as well.
04-11-2018, 11:57 AM | #3 | ||
Previously TUNGA
Thankyou I will try to make a tool up to get behind the cab
04-11-2018, 12:30 PM | #4 | ||
What has a fuel guage got to do with a roadwothy certificate??
04-11-2018, 01:01 PM | #5 | ||
Previously TUNGA
I agree but I was no go as it is
04-11-2018, 03:16 PM | #6 | |||
You can't stop the signal
Just taking the tub liner out won't give you access to the fuel pump.
You will be able to drill out spot welds that hold the tray floor down though. https://fordforums.com.au/showthread.php?t=11313390
05-11-2018, 10:26 AM | #7 | ||
Previously TUNGA
Thanks for the help ,it's a lot of work to get a fuel gauge working now considering selling without a RWC
06-11-2018, 07:30 PM | #8 | ||
