22-04-2021, 11:18 PM | #1 | ||
Hi guys,
I have a te50 which Was handed down to me from family and I’m trying to diagnose the coolant boil issue. After 10-15mins idle the coolant bottle will started to boil crazy. What I’ve looked out for, Seems like it’s got a new water pump (someone tried to fix it before) I put a new thermostat and also tried with no thermostat No oil mix (in water or oil) When on idle at the start doesn’t seem to have air in the coolant system And one have any ideas before I start taking the motor out for major head damage? Thank you guys in advanced. |
22-04-2021, 11:43 PM | #2 | |||
Have you checked the recovery reservoir cap is holding pressure? See https://rxmechanic.com/symptoms-of-a-bad-radiator-cap/ and https://www.holtsauto.com/prestone/n...lant-bubbling/ etc
regards Blue |
23-04-2021, 08:10 AM | #3 | |||
Is there water laying on the side of the head mainly the drivers side head cover / tappet cover ? if so I would be $50 that the rear hose that goes behnind the back of the motor to full of **** from under 20 years of **** its like a 800 dollar fix at a decent mechanic |
25-04-2021, 01:25 PM | #4 | ||
Use a TK Tester? I think you will find it’s got exhaust gases in the cooling system. Which says head gasket problem.
Current Project XE (Track Car) 302 Cleveland and C4 Auto currently. Previous 1973 XB GT Coupe 351 4V, 4spd Top Loader and 9" Diff |
02-05-2021, 07:58 PM | #5 | ||
Radiator fans working?
If the water pump's turning, thermostat opening and fans running it should not boil at idle... |
