Old 21-07-2021, 02:15 PM   #1
Cortina1963
Default chassis number ident for 1962-1964 Mk1 Consul cortina
Hi,
Can't find anything on forums as yet but can anyone out there please tell me how to find out the details pertaining to the chassis number on a Mk1 cortina.
I have just finished restoring a Mk1 Consul Cortina GT. The only number on the shell is 113E six digits M. From the info I can find is that it is a 1963 2door saloon/GT built in November 63. I need to find out all the info as I went to register yesterday and the TMR in Qld couldn't find anywhere in Australia where the vehicle had been registered.Could the shell have been a spare body for racing purposes back in the old Bathurst days?
Cortina1963 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 07:36 PM   #2
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default Re: chassis number ident for 1962-1964 Mk1 Consul cortina
A 63 two door GT is indeed a rare car.
I'm not 100% sure but they could have been British built and bought over for motorsport homologation.
113 is the body type, Right hand drive manual. On Australian cars there will be another number on the radiator support panel, passenger side close to where the grill attaches. The stamping is very shallow (on mine at least) and could easily have been covered by primer and paint, erased by a sandblaster or lost if the panel has been replaced.
Once again not 100% sure but from the info I have the chassis number on British cars is on the compliance plate labelled as 'Vehicle number' under the paint code.
It would start with a B for Britain followed by A for the Dagenham plant
If it does have the BA prefix it might be worth searching UK sites or getting in touch with the Mk1 Cortina owners club over there, although it is a worldwide club.
Escort RS2000 Restored factory a/c and alloys.
TD Cortina Unrestored 35 000km 6cyl manual.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 09:32 PM   #3
Cortina1963
Hi Mate,
I have done a thorough search for the number on the radiator support panel and does not have any visible markings. I cant understand why no record of registration could be found for this vehicle by using the chassis number stamped under the drivers strut.
Old 22-07-2021, 09:58 AM   #4
chappy60
113E is a 1198cc rhd if it is 2door GT it will have the model code
on the plate of 27132 if it has 28112 its a 1200 2 door deluxe
and the 1500 2 door deluxe has the number 28132 if you want
to know anything else pm me
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2021, 05:31 PM   #5
Rallye Sport
RS The Faster Fords
You could also try Motorsport Australia (CAMS) if its ever been logbooked they may have details of previous rego numbers.
FG XR50 Daily.
Old 24-07-2021, 08:15 AM   #6
chappy60
the number on the strut tower is not the chassis number
it relates to the model/engine as previously stated the
chassis number is on the radiator support panel which
in turn should match the numbers on the id plate just
as a matter of interest does it have strip speedo or 3
dials
Old 24-07-2021, 05:35 PM   #7
Rallye Sport
RS The Faster Fords
Yep thats right, it matches the one on the ID plate, if its got no visible chassis number they may should be able to use the one on the ID plate.
A pic of mine and the number on the radiator support if its of any help. As I said the stamping is very faint and easily covered by paint or erased with abrasives.
FG XR50 Daily.
Old 27-07-2021, 07:29 PM   #8
Cortina1963
Hi Chappy 60,
It has a strip speedo. and only 5748 miles. There is no other numbers anywhere visible. My chassis number is 113E941291M. There was aplate attached on the drivers muguard at some stage but it was removed before I obtained the shell.
Old 29-07-2021, 08:06 AM   #9
chappy60
with the paper work i have a 113E shell is a 1200 cortina
a GT would have 118E, strip speedo should read 110 mph
