Da Shifty One
Howdy PPls,
Im a bit confused and very worried. On three occasions, about 2 months apart, my fez stalls for no apparent reason. All three times i have been driving for atleast 10mins with the heater on, radio on and thats it, and have been stopped at the lights. the only thing that is displayed is the engine icon on the dash. I start it up again and its fine. Does anyone have any ideas on this?? Any help would be great Cheers Damian
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - |
Candy White GTI
Its almost 100% likely its that stupid electronic throttle control (drive by wire) i had hassles with mine, where the accelerator pedal had no feel and was unresponsive, idling wasnt smooth either and on a few occasions it stalled.
I had mine computer re flashed by ford and now its all good ![]()
Volkswagen GTI Polo. Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash, Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat Loads of fun ![]() |
Candy White GTI
What i have also noticed is that if you have just been driving and the car is hot, then you stop at the lights the radiator fan will start up sometimes, and when that happens it drops your Rpm on idle. so if your computer has set your idle too slow itl stall when the fan comes on.
Im going to ask for if they can somehow through the soft ware make my car idle just a little bit higher.
Clio 182 CUP!
Weird... i havent had mine stall itself, only when i accidently take off without noticing the idle is low (its warm) and i dont give it enough of the accelerator. I have noticed what you say mitch with the fan... when that starts the engine almost chokes itself when revs drop for about 1second. But in an auto, i would get that checked out! Auto shouldnt stall really...
I did have problems with start up when the car was new... i would try to start the car and it wouldnt tick over. But its all good now... weird.
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
Rollin
i thought the fez was electronic accelorator , not by wire like the barina sri.
GT4.
You mean cable throttle Groov3? As "Drive by Wire" and Electric Throttle are the same thing.
As for all these problems, I havent experienced ANY of them touch wood. I may just have a good fez, donno, so far so good. Just take it back anyways Mista Fiesta i'm sure ford will tell you its "normal" ![]() |
#7 | |||
Rollin
woops thought you mean throttle by cable when you said wire, sorted, either way he should be taking it back to ford to get the ecu remapped or fix what the problem is if its not that. mine has stalled once thrashing it down this road pulled up to the t junction went to take off on to see a arange of lights in the dash on it had stalled for some reason but never had any issues since then |
XR5T - Sea Grey.
It seems strange that cars ECUs aren't updated automatically before delivery, instead of doing it at the next available service.
Zetec Screamer....
I had a similar problem with my Focus. Took it to Ford and they reflashed the ECU claiming there was a TSB on the problem and the Flash of the ECU fixed the problem.
It still stalled at times, back to Ford and now they found rust deposits on the spark plugs. They cleaned the spark plugs and now no probs. Get Ford to reflash ECU and clean ur spark plugs. Tom |
Da Shifty One
Howdy,
Thanks for the help. Ive booked my self in on wednesday at Jubelee Ford Five Dock. Hopefully they will underdstand the problem and fix it ie ECU update.
bah i had the same problem today at the roundabot .. i was turning then suddely the engine icon turns on, steering wheel suddenly locks up and speed drops -___-;; so i steered (with alot of effort) towards the side and turn the engine off and start it again .. then its fine o.o;;
should i go to the dealer to reflash the ecu and clean the spark plugs? how much will it cost? |
#12 | ||
Fairmont Ghia
It shouldn't cost you anything, if you feel there is a problem, they should look at it for nothing for you under warranty.
I think it's just because everyone's Fiestas are too used to sitting on 7 grand, when it gets down to 1 grand the engines get scared and panic! ![]() I've seen Fiesta drivers on the road! ![]() Tim |
not here much anymore
If your Fez is stalling its most definitely a warranty problem and you should not be charged a cent for it.
And in regards to ECU updates being put in at PD time, the way I had it explained to me is that sometimes they are not always required or beneficial to every single Fiesta, so they let them get worn in for a while and if the issue arises or is still there at service time, it is done then. That, and its not always possible to flash the cars before they are delivered - flashes take time to develop.
RAM 1500
#14 | |||
Clio 182 CUP!
