Boost Addict
ok questions are:
ignition: coil pack or dizzy? if coil on-plug or remote? head: cast or alloy? AFM or MAP? injector size? throttle body size? engine gridle: yes or no? Cheers Mic
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
![]() Join Date: Jan 2005
Yep, I can see the questions, but what are they in relation to? A T series V8? If so, which model (1, 2 or 3). Or are you talking a Turbo I6?
In aufalcon forum it'd have to be T-series. I don't have one but will try to answer...
Ignition: remote coil packs. Head: cast on all 200 motors, alloy on all 220s and 250s IIRC. AFM. Injectors: I think maybe 24lb on all but dunno. TB size: 65mm on 200s, 70 on 220s I believe - unsure of 250 but maybe 75?? (probably 70). Engine girdle: Not on 200 or 220s. Yes on 250s. Someone can no doubt clear up the ones I'm unsure of. NB. T-series: 200(kw) = AU1 TE and TL. 220(kw) = AU1 TS and I believe all AU2. 250(kw) = 5.6 stroker = all AU3. Steve. |
Boost Addict
excellent thank you
i am just trying to figure out what parts i will need to buy cheers mic
#5 | |||
Silhouette AU1 TS50.
Ignition: Remote coilpack.
Heads: 200kW = Cast iron. ...........220kW = SVO alloy up untill April 2001, cast iron there after. ...........250kW = All cast iron. AFM or MAP: MAP. Injectors: Bosch 24lb (part # 0 280 155 903) on all. Throttle body size: 200kW = 65mm. ............................220kW = 70mm. ............................250kW = 82mm. Engine girdle: Only on 5.6 250kW. Quote:
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
Actually isn't a MAF sensor, not MAP - the I6s have a MAP (Manifold Absolute Pressure) sensor in the manifold; the V8s have a Mass Air Flow (MAF) meter in the intake tubing.
MAF is 70mm (actually 68, I think) on 185, 200 and 220, 75/80mm on 250.
Yeah, definatley MAF type AFM on all eights. Thanks for the other corrections though 012.
#8 | |||
