Old 17-06-2006, 01:23 AM   #1
ronzky1051
Ford Addict
ronzky1051's Avatar
Unhappy Fuse House telstar TX-5
Hi
I have a ford telstar TX-5 and i have some problem..
-My Fuse house was burned (power window Fuse exactly) in flames when i was driving my car to my college..this thing happen right after i repaired my power window..
Does anyone have a solution in this..and i wonder if someone have an idea about this car modification....
Thnx B4..... :eclipsee_
out: Bang-Bang out:
ronzky1051 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 03:15 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
ok the earth wire must not have been secure at the fuse box
or the motor you were given was faulty
there was a switch was the window working after you refitted the motor
also were the wires through the door to body cut or damaged to cause the power wire to spark to earth out before the fuse ?
how much damage to the wiring and it looks as if the fuse didnt blow
first you need to go back in and test the motor and switch
replace the burnt wires get a good earth
and then check the amperage between the fuse contacts
i have got a wiring diagramme for the power windows if you need it
My car goes Brumm Brumm
Old 17-06-2006, 03:34 AM   #3
dirty hands
Over Thinker
had a look into the wiring diagramme
only one earth for all 4 window motors you may have a faulty main window operating panel or a switch or one of the other 3 motors is also not right
its not going to be a fun job tracking down the fault
you will need to have a volt meter or a continuity meter
you may have to go to an auto electrician to get that fixed
Old 17-06-2006, 12:54 PM   #4
ronzky1051
Ford Addict
ronzky1051's Avatar
Thank's 4 Your advice..
anyway can i have the power windows wiring diagramme that you have?
maybe i'll give it a try..
out: Bang-Bang out:
Old 17-06-2006, 04:20 PM   #5
dirty hands
Over Thinker
Thumbs up wiring diagramme
if you cant read it print it out and photo copy or I can email it to you
