19-06-2006, 12:12 AM | #1 | ||
Formally Kia Chaser
With all the talk of LED lights, and dash globes replacing, etc, I may endevour on a new idea that just oocured to me.
A relativley new LED has been on the market for a while now. It's known as a RGB LED (Red green blue Light Emmiting Diode). One such exaple can be found here (http://www.ledsales.com.au/cart.php?...&substring=rgb) and catagory of them here (http://www.ledsales.com.au/cart.php?...category_id=11) What about the idea of replacing all internal lighting to these LED's, then hooking them up to 3 potentiometers to mix the colours. These LED's have a seperate reg, green and blue LED in them, which can be mixed for most colours including white. So you could provide max current on each for all white lights, etc, etc.... What do you guys think?
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
19-06-2006, 12:15 AM | #2 | ||
Good idea, but lots of work. Let us know how it goes.
19-06-2006, 12:30 AM | #3 | |||
Fantastic Plastic
19-06-2006, 12:48 AM | #4 | ||
i'm keen
19-06-2006, 11:57 AM | #5 | ||
Tickford Equiped
It is very doable, but would there would be a fair bit of wiring & stuffing around. I have thought about it in the past, but its just to much work, maybe sometime in the future i will get around to it.
It would be a very nice mod to do, you could adjust your dash as you like, also you could do further interior mods, run LED's in the door handles, change footwell lights over etc, so that you could run them the same, and change them as you desire. If you get around to it make sure you do up a document on it with pics. Cheers & goodluck.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
19-06-2006, 12:25 PM | #6 | ||
Formally Kia Chaser
Went to the can for a bit of a think over this. As much as it is a cool idea, I don't think that I'll be doing it... mainly due to all the stuffing around....good idea for someone else... adjustable mood lighting - lol
19-06-2006, 12:42 PM | #7 | |||
Fantastic Plastic
19-06-2006, 12:46 PM | #8 | |||
Audi S3
19-06-2006, 12:54 PM | #9 | |||
Fantastic Plastic
I also found that the CFP needed an extra led on the left hand side to light it up propperly / evenlly , which was easy as there is allready a square hole notched out in the back of the centre face panel where you can mount a led to glow into , just power it off 1 of the other globe contacts next to it . If your gonna mod the smaller lights , just untwist the old wiring from the globe holder and remove the globe , thread the legs of the led through the holes , mount the resistor on the rear of the base , then a bit of heatshrink over it , then use the rest of the + wire from the resistor and the - leg of the led to re-wrap around the grooves in the green plastic base (to make the contacts again ) . Oh , which reminds me ! - Im not to happy with the clock and the odometer/dte lcd's using led's to light them . Because of the low beam angle of led's the clock seems mainly be lit around the centre more than the edges , im planning on adding another 2 led's to the clock to fully light it evenly , so all up the clock will have 3 led's ... same with the ODO/DTE lcd , lights up ok but needs more led's to spread the light evenly , which i will be adding to both soon .. This is why the left side of the CFP doesn't light up propperlly either with led's , and needs the extra led . The spacing of the dash lights and elec window switched seems to be fine with led's .
------------------------------------------------------------ :eclipsee_ Last edited by XR6-VCT-2000; 19-06-2006 at 01:11 PM. |
19-06-2006, 03:32 PM | #10 | ||
Audi S3
it seems we are talking about different lights here i think. cause of the different dash's something got lost in translation...
19-06-2006, 04:27 PM | #11 | |||
Fantastic Plastic
