26-02-2007, 01:19 PM | #1 | ||
LWBforME
Anyone have an idea why when I press the boot lid unlock button on the remote pad, it does not work? All other remote functions are OK.
26-02-2007, 01:31 PM | #2 | ||
does the boot release button on the dash work?
26-02-2007, 01:56 PM | #3 | ||
Now with an AU XR6
Also does the LED on the remote come on when pressed. First thing I would be looking at would be the dash button, then the battery in the remote, and finally the connections internally. Something could have disconnected meaning there is no continuity in the remote for that button. Something may need to be re-soldered.
Stop chasing me! I don't have any donuts! 1999 AU1 XR6 VCT - Now with a momo steering wheel! Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs Team Deck Chair Member ............ Once you sit down, you'll never stand up. |
27-02-2007, 12:05 AM | #4 | ||
2003 BA XR8
I had that just recently. Boot button wouldn't open. But I could still lock the car like a charm. I opened the unit, pulled the battery out, put it back in, resealed it... and she worked like a charm.
27-02-2007, 12:34 PM | #5 | ||
LWBforME
Cheers, guys. Yes the boot button on the dash does work. I will try the battery in the remote. Either replace battery or examine connections.
27-02-2007, 02:48 PM | #6 | ||
Iam having the same problem, boot isnt releasing from dash or remote.Light in boot not working either.
27-02-2007, 02:52 PM | #7 | ||
check your wires from boot foward, sounds like an unpluged harness somewhere if both are out
19-08-2007, 06:41 PM | #8 | |||
XLR8
Cheers TJ |
19-08-2007, 09:24 PM | #9 | ||
Smile
The rear boot has a solenoid like a central locking one only much bigger. Does the boot open when you press the physical switch on the dash board? If not check the fuses.If the fuses are ok then remove the boot trim and make sure the solenoid has a good earth.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
07-09-2007, 04:24 PM | #10 | |||
XLR8
Still avoiding the stealer on this, as the last time SHMBO took the car in for this same issue a few years ago they replaced almost everything and cost me lots!! |
