Old 21-10-2007, 10:05 PM   #1
jimmyshaker
Question partrol mavrick engine convertions with v8's
what is invoved & what you need &cost$$$$$
jimmyshaker is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2007, 10:06 PM   #2
waggaclint
waggaclint's Avatar
what the???
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2007, 10:12 AM   #3
InfernoSR
Sales Representative
InfernoSR's Avatar
I think he wants to convert a Patrol/Maverick to a V8... maybe an A-series V8...
Old 22-10-2007, 06:52 PM   #4
Patrol351
OFFROAD ART
Patrol351's Avatar
go to www.outerlimits4x4.com and check the nissan section ....
theres plenty of threads with V8 conversions with holden 5.0L and LS1s
and theres some info on windsor and clevo jobbies
u won't have much change out of 10grand i reckon
Patrol351 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2007, 11:16 PM   #5
blownba
LPG Forum Moderator
blownba's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all his assistance helping members with their LPG issues.
I did a windsor in a GQ many years ago. NEVER AGAIN!!!!!!!!
But I have been involved in a few conversions on various 4wd over the years.
All adaptors and mounts ect for a windsor will have to be hand made as there are no comercially available convesion kits that I know of. It has to be done right to get everything placed like OE.
10 grand???? Even a straight forward 350 with all Marks adaptors will set you back more than that. And don't forget it needs to be engineered to be legal and roadworthy.
Its not the end of the world but the only advice I can give you and this applies to any modified project, is to STAY COMMITED and do your homework before you start.
Too many guys I see are full of beans and ideas to start with but as soon as they realise what is involved they go off half arsed and stop doin things right cut corners and it all goes tragically wrong.
If ya wan't the cheapest option go a stock crate 350 and you can pick up everything you need to make it fit from many different suppliers and then run straight gas or dual fuel. Last one I helped with cost about 12 grand on the road and engineered, inc labour bill.
They are an awesome thing when done though. They really should of had an eight factory cause the chassis more than handles it.
blownba is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 06:50 AM   #6
castek
we had a GQ i think (1991) patrol. with the sluggish RB30. the used used to die up a small hill on the highway and was very impractical. so what did we do? RB30DET conversion time. been done loads of times and is a great surprise to unsuspecting 4wd owners.
castek is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 08:01 AM   #7
fairBA
fairBA's Avatar
don't - trade up and get yourself a 100series or, wait 2 weeks and look at the 200seires.
i would stick with the 100 series until 200 proves itself though it should
fairBA is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 08:05 AM   #8
dallasv8
5.8 litres of fun
dallasv8's Avatar
i seen a maverick trayback in townsville a while back at the BP where thay had a little track thing set up for time trials.i think it had a 351 clevo and it was cutting sick, bloody awesome the way the guy threw it around.
2003 RTV
2015 Ranger XLS mk2
dallasv8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 10:42 PM   #9
PaulMac
Done a couple of Landcruiser 40 & 75 series engine swaps, got one the yard to do after the EB2 is finished. Don't be put of by the amounts being quoted as the wiser you buy essentials and the more you do yourself the less it costs. Listen to Blownba's advise about crate small blocks, plenty of uncommitted individuals put their gear up for sale fairly cheap. Marks kits also come up second hand, they are well made and just bolt up. Too many issues to use Ford V8's, especially with sumps etc., can be done but time and money consuming out of all proportion to any gains. Chev kits and detailed instructions are common for a good reason. The easiest option by far is going the way Castek suggested (I used a new 1990/1 Patrol for a very short time too, good off road but couldn't hold a candle to my FJ75 on it) but there's no denying how good a V8 sounds, even a Chev!! Marks Adapters used to have heaps of info about various engines on their website, try there as well as the links above.
Paul
PaulMac is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 11:15 PM   #10
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
gen3 all the way if you want a V8 , there are plenty of kits around and they make good power and are light.
If you just want a power upgrade just efi the TB42 and wack a small turbo on the side. lots of power and not much stuffing around.
mine has made over 200rwkw, no V8 is going to make that power N/A
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
