Old 28-08-2008, 11:43 AM   #1
jaydee
jaydee's Avatar
Default Can anyone ID this old car please?
Found this old pic of my Dad with some old car he used to own.
It looks like it's been converted to a ute but I don't know what it is, any ideas.
Thanks.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 12:35 PM   #2
Fev
Fev's Avatar
home made ute! brilliant!
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 12:38 PM   #3
FORD5
FORD5's Avatar
The cabin looks like an old ford hot rod, with the soft top and home made tray. brilliant
FORD5 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 12:39 PM   #4
FORD5
FORD5's Avatar
They have the winch on the front you have to turn to start her.
Old 28-08-2008, 12:49 PM   #5
Ando_Leigh
Ando_Leigh's Avatar
Pretty sure it is pre 1934
Looks like a 32 5 window coupe converted into a roadster ute.
Apparently their were quite a few home made utes back then. One of the many reasons ford built the first ute in 1934
BA MK11 XR6- Black
Ando_Leigh is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 12:59 PM   #6
jaydee
jaydee's Avatar
Thanks guys, still not sure though.
I thought Ford too because he called it Lizzy but it's not a T.
What throws me is the soft top with the metal arm, it looks factory, might have had a dicky seat.
jaydee351
4DV8
Old 28-08-2008, 02:43 PM   #7
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I'd go along with Ando, the grille is upright like a 32 rather than the later years which were angled, and the windscreen is angled rather than Model A's which were more upright and the entire front bodywork a bit smaller. The converted-coupe aspect would explain the solid panel behind the door although the belt-line moulding in the panel doesn't look quite right - not really clear though. Ford5 it is a starting handle not a winch! It is possible it might be another make - people say cars all look the same today but it was like that in the 1920's & 30's too, you need to pick differences in radiators & grille shells etc.
Old 28-08-2008, 02:50 PM   #8
Charliewool
Bolt Nerd
Charliewool's Avatar
I reckon it's a 33 by the headlight position (on guards)
Before the "mods" I'd say a 5 window "sports coupe"??
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 02:55 PM   #9
GasoLane
Former BTIKD
GasoLane's Avatar
HAHAHA... Brilliant. It was called a 'crank handle' but I think when this one came out Starter motors were invented
Old 28-08-2008, 02:57 PM   #10
FORD5
FORD5's Avatar
GOSH! sorry *crank handle you knew what i ment!
Any way it looked like a hot rod to me with the giant side steps, but it may not be
Old 28-08-2008, 03:00 PM   #11
FORD5
FORD5's Avatar
you have a look. see how the side steps are linked with the wheel guard/arch
id say some sort of hot rod...
Old 28-08-2008, 03:07 PM   #12
Charliewool
Bolt Nerd
Running boards bud
Old 28-08-2008, 03:16 PM   #13
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Yep, I'll go 32/33 Ford... Fantastic photo too - It's excellent to have that kind of thing, usually they get lost through generations.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 03:31 PM   #14
Ando_Leigh
Ando_Leigh's Avatar
I will be able to give you about a 99% sure answer when i go home.
Need to have a look over a few old rodding mags just to get that front bonnet gaurd shape.
As outback_ute has said ford and chevs of the era were very similar.
The easiest way to tell was front grill and lights or rear lights as well.
After having a better look over i am starting to think it may be a 32 chev just the way the front guard comes down and the vents in the bonnet.
With many of the early cars the model was kept for two years so i can be hard to norrow it down to the right year.
E.g
30-31 model A
33-34 i think were model B. i think 32 may be this aswell
35-36 i have heard a couple dif thing but model 48 seems to the most common
Between say 33-34 the only difference in the car was the grill really and a couple of different little bits in the cowl.
BA MK11 XR6- Black
Old 28-08-2008, 03:32 PM   #15
Ando_Leigh
Ando_Leigh's Avatar
just noticed got to love inner tubing in the tyers
BA MK11 XR6- Black
Old 28-08-2008, 03:37 PM   #16
TC200six
It has suicide doors so if it's a Ford, it's the Model B Ford V8, the successor to the model A. It would be the first of the model B's (1932ish) because it doesn't have a slanted grill.
TC200six is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 03:42 PM   #17
TC200six
Originally Posted by Ando_Leigh
As outback_ute has said ford and chevs of the era were very similar. The easiest way to tell was front grill and lights or rear lights as well.
Not that you can tell in this picture, you could also tell the difference between a Ford and a Chevrolet by their differentials too.
Old 28-08-2008, 04:09 PM   #18
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
The old engineer at work suspects it's actually a Dodge going by the cowl and headlight position.
I personally have no idea, it's well and truely before my time and even before my fathers time.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 05:56 PM   #19
KJay
As mentioned probably a 1933 Plymouth or Dodge coupe.
Might have had a rumble seat. But it has an earlier roadster hood fitted.
Dodge
Plymouth
Great Photo..
Cheers..
KJay is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 06:10 PM   #20
Charliewool
Bolt Nerd
33 Ford... ..
33 Dodge...
Note rib along door?.. Maybe it is Dodge?
Old 28-08-2008, 06:49 PM   #21
ZEDAYE
20 INCH 100 SPOKES
ZEDAYE's Avatar
Maybe a 1933 Plymouth? Check the attached picture, they have a similar bodyline where the door meets the hood, suicide doors and the gaurds have a similar arch shape. Wicked old picture!!
ZEDAYE is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 07:26 PM   #22
TC200six
Originally Posted by charliewool
If the car in the picture is a Ford, it's not that model because it does not have the slanted grill.
Old 28-08-2008, 07:28 PM   #23
TC200six
I think you've found what it is!
Old 28-08-2008, 07:30 PM   #24
Abacus
Life's a Gas
Abacus's Avatar
It's a Dodge.
Compare flutework along the sides of the bonnet, headlight mounts, roofline and door mould with charliewool's pic.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 07:38 PM   #25
Stefan
Stefan's Avatar
I'm going with the 33 Dodge, grill, cowel, hip line, door hinges, detail above the running boards are all identical...
Cool cars...
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 08:44 PM   #26
Ando_Leigh
Ando_Leigh's Avatar
Def not a ford as the door has only two hinges ford had 3. Also the flute work in the bonnet is all wrong.
Ok don't think it is a chev as the front guard comes down and then don't cut back sort of square 32 chev only had 3 pull out flutes in the bonnet and 33-34 chev had horizontal flutes. Ford and Chev had pretty much the same wheels that year and apparently that is not a ford or chev wheel in the back but a dodge (yeah that was a little freaky the new that)
So we are pretty sure the winner is a 33-34 dodge sports coupe cut down and converted.
So I am 99.9% sure that it is a dodge.
The only other one it could just be is a Plymouth as we don't know too much about them.
Hope that helps.
Just to let you know this info didn't come from guys from that peroid ethier just two very keen hot rodders that know there stuff.
BA MK11 XR6- Black
Old 28-08-2008, 09:33 PM   #27
Spanrz
Hmmmmmmm!!
Dodge I think by the pics. For me too.
The headlight spacing away from the grille is the giveaway. Ford is very close, Dodge has a large gap.
Spanrz is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 11:02 PM   #28
jaydee
jaydee's Avatar
Great work guys, I'm going Dodge too, especially when you look at the air venting on the bonnet and the swaige lines on the door.
Thanks heaps.
This pic was taken in the Kimberleys of WA about 1953 on a visit to Anna Plains Station which is about 250 kays south of Broome.
God what was he thinking driving this through that part of the world.
jaydee351
4DV8
Old 28-08-2008, 11:21 PM   #29
dave351cid
playing in my big shed
dave351cid's Avatar
these old cars didnt need roads, they drove them just about anywhere. not like the wimpy cars we have today.
my fathers first car was a model A ford that was cut down and turned into a ute . that would have been about 1943 i think. sadly no photos of that one.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2008, 11:27 PM   #30
Elks
Elks's Avatar
It is Plymouth/Dodge 32 or 33 vintage.
It is not a Ford and I don't think it is a Chev.
It is the version they referred to as Cabriolet. As it has glass side windows and cloth top. Love the chrome trim Would have been a side valve in line 6.
A roadster would have fixed windscreen and cloth sides, and a coupe obviously would have glass sides and steel roof.
Clearly this car has then been modded to become some sort of ute.
Cool though.
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
