Old 28-03-2009, 06:21 PM   #1
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Cluch start in reverse??
While waiting for my dad to finish work I went over to 2 middle aged ladies in some sort of Suby. The bonnet was up, and they were looking under there while one was on the phone.
I asked what the problem was, and they said the battery was dead, and the NRMA was on the way. I didn't have access to jumper leads.
Their car was parked on a slight incline, facing up the incline.
Sooo.... can you clutch start a car in reverse same as you would in 2nd gear rolling fwd?? I know reverse gearing is a lot shorter than 1st, so would the car come to life then take off uncontrollably like a bat out of hell??
Not that I will come across the same situation again lol.
Jason
Old 28-03-2009, 06:27 PM   #2
Unco
Unco's Avatar
yes.
done it plenty of times in the past when i used to have a celica, a flat battery and a steep driveway.
Unco is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 06:29 PM   #3
Jesk
certified nutter
Jesk's Avatar
yeah you can do it no worries, done it in my festi and other little cars too
Jesk is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 08:59 PM   #4
XR6_190
BF XR6, oh yeah!!
XR6_190's Avatar
Yeah, saw a bloke in a Commodore do it the other day, and my neighbor used to do it all of the time with his old POS Astra.
Current ride: 2005 BF XR6 Sedan, Lightning Strike, ZF Auto
Previous ride: 2001 AUII Futura Sedan, Narooma Blue
XR6_190 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 09:37 PM   #5
pauljh74
pauljh74's Avatar
Yes, I have done it a few times in the XE I had out of the short, steep driveway where I was residing a few years back. Only need a little speed to turn the engine over with the short reverse gear. The same would apply if you were facing downhill and chose 1st to turn it over.
Once you feel it fire, clutch back in, make sure it keeps revving and drive normally from there
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 10:42 PM   #6
BOSSGT302
BOSSGT302's Avatar
Yes, but when it starts going like a bat out of hell, remember to use clutch and brake to solve new problem. LOL
Silhouette BOSS302,
Just as The "Good Ford"Made Him
BOSSGT302 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 10:47 PM   #7
Zed7fiddy
Temporary Australian
Zed7fiddy's Avatar
yep, msot certainly can, my work ute (96 deisel hilux) has a POS electrical system, it needs to be jumped daily, so we NEVER park it on a flat. once we did, so we needed to jump it, and walaahhh jumped in reverse! doen it a few times now!
Zed7fiddy is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 12:02 AM   #8
Yellow_Festiva
Where to next??
Haaaa ok no worries then. I may just practice it in the Festi myself when I have nothing better to do lol
Cheers,
Jason
Old 29-03-2009, 11:25 AM   #9
brycieboy
brycieboy's Avatar
im pretty sure your not ment to do it in reverse.... tho it can be done... but im sure someone once said to me that there is a possobility of winding the engin over backwards...
brycieboy is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 11:49 AM   #10
3vXT
3vXT's Avatar
Ummm... when you shift into reverse the crank does start spinning the other way. Haven't you seen Titanic?
3vXT is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 12:01 PM   #11
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Not usually. Reverse and 1st are often very similar.
I don't know whether bnsuteau or ken2903 are kidding, because the motor doesn't change its operation no matter what the transmission is doing. The motor doesn't care! the same direction of turn comes out of the flywheel no matter what your trans is doing.
Mate of mine used to do it in his LJ Torana all the time. No probs at all.
Old 29-03-2009, 12:07 PM   #12
3vXT
3vXT's Avatar
Yes i was kidding lol.
(hence the italics)
Old 29-03-2009, 01:01 PM   #13
Mr Hardware
oh sorry, i'm sick, my brain isnt working quite right.
do you think bnsuteau was kidding?
Old 29-03-2009, 01:14 PM   #14
3vXT
3vXT's Avatar
Maybe not, i've heard it mentioned before.
Will an engine rotate backwards if your car is in reverse but rolling forward (on a steep hill i guess) with the engine off? surely something in the gearbox would let go first?
and if it was on a giant treadmill would it take off? kidding
Old 29-03-2009, 01:27 PM   #15
gtxb67
moderator ford coupe club
gtxb67's Avatar
i remember years ago in an f1 car, damon hill spun and the car went backwards while in gear, without his foot on the clutch. when the engineers found out they changed the engine in case it went backwards. certainly a grand prix car would have a stronger gearbox, but i assume you do not want it in drive going backwards or reverse going forwards
obviously if it is neutral or going in the correct direction for the gear, it should not be a problem
gtxb67 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 01:35 PM   #16
3vXT
3vXT's Avatar
Yeah the T5 in my BA feels like its made with paper mache, chopsticks and a big **** rubber band so i won't be trying any hill starts in either direction or gear
Old 29-03-2009, 02:34 PM   #17
Unco
Unco's Avatar
did you pay extra for the chopstick reinforcement?
i'm curious now, and it's doing my head in. if the engine did manage to spin backwards, with the ignition on... would it then start rotating the other way using the exhaust valve as intake and the intake valves as exhaust? imagine the damage that would cause.
this is what happens when you work night shift and wake up at 1.30pm and read threads like this.
Old 29-03-2009, 04:35 PM   #18
86XFFairmont
No Car Too Low Too Tow!
you can start any manual car in either 1st or reverse (could do damage in rev), even when its stuck in gear and clutch is gone just to move it around just have to turn off to go back or forward
If it goes like a Zirtec, Why am i towing it?
86XFFairmont is offline   Reply With Quote Multi-Quote with this Post
