Old 12-03-2011, 02:17 PM   #1
DoggyGT
In Pursuit
DoggyGT's Avatar
Default Stolen parts and equipment, Sydney
Hi guys, just had this sent to me, just putting it out there for everyone,
"Please spread the word.
I hope you don’t mind me using the club email list to do this, but some good friends of mine have had their workshop burgled and I have offered my support in spreading the word.
They own Advanced Performance Machining in Smeaton Grange and run a private top alcohol drag racing team (Team APM: http://www.teamapm.com/). On Sunday night they were completely cleaned out of all of their race motors, a heap of racing gear, plus a whole heap of their customers motors which they were building, all totaling in excess of $300,000 in stolen goods.
Unfortunately their insurance doesn’t cover this sort of loss, so the team is up for sale and everything they have worked hard for (including the national ¼ mile record and leadership of the current championship) has been lost.
Attached is a comprehensive list of items and parts that have been stolen, many of which I believe are unique. In the slight chance that you or someone you know has exposure to the drag racing world, or even the higher end of modified cars, would you mind forwarding this email on and keeping an ear out for any information that may help the Hambridge family track their parts.
Any info can be passed on to Aaron or Steve Hambridge on 02 4647 1181 or Crime Stoppers on 1800 333 000.
Thanks for your time guys,
Matt Amato
For your information. Please see below explanation.
Please send this on to anyone you may believe could assist and to get word out about this theft.
Cheers,
Peter Czerny
Vice-President & Treasurer
Highland Cruisers
PO Box 211 Thirlmere NSW 2572
APM STOLEN PARTS LIST
SMALL BLOCK CHEVY TAKEN COMPLETE ASSEMBLED READY TO RUN
DART BLOCK
CALLIES CRANKSHAFT
HOWARDS ULTIMATE DUTY CONRODS
CUSTOM DIAMOND PISTONS
HOWARDS ROLLER CAMSHAFT & LIFTERS
BRODIX CNC PORTED HEADS 23 DEGREE
JESEL ROCKERS
JESEL BELT DRIVE
NEWBY MANIFOLD
KOBELCO K9 1471 SUPERMAN BLOWER
MSD MAGNETO 44 AMP
ENDERLE110 FUEL PUMP
RCD CRANK SUPPORT
BDS BILLET IDLER
RCD MAGNETO/ FUEL PUMP DRIVE
14MM PULLIES/ BELT
KNUT CARBON INJECTOR HAT
ENDERLIE BARREL VALVE
RUBBER LINES
SYSTEM 1 OIL FILTER
MILODEN OIL PAN
MOROSO BILLET OIL PUMP
FOWLER OIL PUMP DRIVE
408 FORD CLEVELAND IN PIECES
SCAT 4340 4” CRANKSHAFT
ARP MAIN STUD KIT
ARP HEAD STUD KIT
COMP CAMS CUSTOM ROLLER CAMSHAFT
COMP CAMS LIFTERS
ROLLMASTER TIMING CHAIN SET
FELPRO GASKET SET
FELPRO 1013 HEAD GASKETS
CLEVITE H BEARINGS
MAINS SUIT CHEVY ROD
MAHLE FORGED PISTONS & RINGS
WELSH PLUG KIT
MELLINGS STD VOLUME OIL PUMP
ARP OIL PUMP DRIVE SHAFT
CHI 225 HEADS COMPLETE, MANLEY RACEMASTER VALVES
ISKY SPRINGS
MANLEY TOOL STEEL RETAINERS
MANLEY 10 DEGREE LOCKS
MANLEY LOCATORS
PRW FLEXPLATE
HOWARD CAMS BILLET ROCKERS
ARP ROCKER STUDS
MANLEY GUIDE PLATES
SCAT H BEAM CONRODS
CUSTOM 1 OFF MORRISON MOTORSPORT IR EFI MANIFOLD
460 WINDSOR IN PIECES
EAGLE 4.250” WINDSOR CRANKSHAFT
EAGLE 6.200” H BEAM CONRODS
CHI 225 HEADS BARE WITH MANLEY SEVERE DUTY VALVES
CUSTOMS DISH TOP CP PISTONS SUIT ABOVE COMBO IN 9.500” BLOCK
COMPLETE BLOWN SMALL BLOCK CHEVY READY TO RUN
GMPP 4 Bolt block
RPM Steel 383 Crank
RPM H Beam 6” Conrods
Mellings standard pump
ARP drive shaft
Rollmaster Chainset
Camtech custom solid f/t cam and lifters
SRP forged pistons
Dart 215 alloy heads complete
Howards rockers
Polished alloy pan and covers
Polished manifold
Weiand 671 blower and dual 750 carbies
SONNY’S 5” BORE SPACE ENGINE PARTS
7 new Childs and Albert conrods and JE pistons
RCD crank support new
RCD Ider with external support new
Custom 1 off billet intake manifold
1 x new Dan olson oil pan
Barnes single stage oil pump
RCD Fuel pump extension
2 x 11mm pullies new 55t, 52t
T & D rockers
Pushrods
408 FORD CLEVELAND PARTS
Mahle forged pistons
Clevite bearings ‘H’
Scat 4” 4340 steel crank
Scat 6” h beam conrods
Yella Terra steel flywheel
Romac harmonic balancer
4” stroke -3 Scat custom order light weight SVO crank
MGP Alloy rods and Racetech Forged pistons – suite SC1 ford heads
355 HOLDEN UNASSEMBLED
308 block fully machined, fitted with milodon 4 bolt main caps and ARP main studs
Scat 355 cast crank, scat 5.7 H beam conrods
SRP forged pistons
ACL main and clevite rod bearings
Camtech hydraulic cam and lifters
Yella terra rockers
JP Oil pump standard volume
Rollmaster chain set
ARP ½” head studs
Fabtech gasket set
Felpro oring head gaskets
Danakis 671 supercharger
Enderle bug injector hat
Racer pro raised runner SBC cylinder heads
Complete
BIG BLOCK CHEV 588 CI VALVE COVERS TO OIL PAN
Bowtie block
Eagle crank 4340
Eagle H beam conrods
CP pistons
Mellings oil pump
Milodon full length oil pan
Donovan gear drive
Howards roller cam
Crane lifters
GM rectangle port heads
Manley Valves, springs, retainers and locks
Howards Rockers
Manley Pushrods
Powerband balancer
Custom ported and modified
Weiand clevo tunnel ram
Valley tray removed
Epoxied and extensively ported
2 x 2” HVH billet spacers
2 x 750 Custom Pro systems carbies
ARP studs, Enderle linkage kit, speed flow fuel lines
FE FORD PARTS
Eagle 430 Steel Crank
Edelbrock heads
SRP pistons
BAE Billet Hemi Block
Custom CP 308 Pistons
X forging, rings etc
632ci BBC Assembled short motor
Dart block
Lunati Crank
Oliver conrods
Custom CP Pistons
Clevite bearings
Rings
Scat 9000 crank
Scat H beam conrods
Edelbrock performer RPM heads
Probe forged pistons
Clevite bearings
Powerbond harmonic balancer
BIG BLOCK CHEV PARTS
Eagle 4.25 4340 crank
Procomp belt drive
Crane roller cam
JE Pistons
Enderle S & U injector, complete with arms, stops
Enderle nitroBV ,stainless hardlines
Purple butterflies, 80 A fuel pump
Belt Drive kit
3 way shut off
SBC Mahle pistons
Clevite bearings
ARP 12 pt head stud kit
Clevo Parts
Balancer
Bearings
Chainset
Alan Johnson 481x cyl heads bare
20 sets cam bearings
6 x 308 neoprene holden seals
Enderle 1200 fuel pump
Custom CP Pistions suite Windsor coated pins, rings, locks
x forging
4ZE1 pistons / rings std .5mm oversize
Manley steel retainers LS1
Manley LS1 valves
Manley chevy sbc intake valves
5SFE Toyota gasket set
PRW water pump suite sbc
1x box of Joe Gibbs Hotrod 15/50 oil
1x box of Joe Gibbs Hotrod 10/30 oil
LA Kryptonite sprint car crank 3.825” stroke
1x Micks Metal craft sheet metal manifold suite VN headed holden with 2x new 750 holley carbies, 2” open spacers, linkage kit and K&N filters
1x Cain polished early 308 manifold with 2x new 650 holley carbies 1” spacers, linkage kit and K&N filters
1 set of ported VN holden v8 cyl heads with roller springs and titanium retainers
misc tools and equipment from the work shop
Race car parts from shop and in the trailer
1x complete BAE short motor, Bryant crank, MGP alloy rods, JE pistons, Moroso Oil pan, Pluger oil pump, Casale gear drive, Crane 60mm camshaft, Jesel lifters, NRE billet idler assembly, Titanium crank hub and degree wheel, crank trigger and bracket.
2x complete triple sprag B&J transmissions, with blankets
2x complete MSD pro mag 44 ignition systems with 1 Dunn offset mag drive, points box’s and coil’s
1x Waterman 800 fuel pump
1x 8 stand 8 lever Eastwest titanium clutch with 4 clutch packs
2x RCD starter motors 1 all billet style 1 old style with billet frame
2x sets of starter cables
2x 48 volt battery packs
1x set of custom Manley valves to suite NRE X1 cyl heads
1x set of 1460 Manley dual springs
3x new 11mm GT blower belts
1x set of MGP conrods new
12x Diamond pistons , pins, rings and buttons new
2x new Simpson chutes in boxes
1x set of T&D fathead rocker gear
1x set of NRE X1 cyl heads complete
1x Simpson Race gear bag with all my gear, Impact helmet, RPM -20 suite, Simpson carbon x underware, Simpson Hi top boots and sox, HANS device, Simpson Balaclava, Simpson arm restraints, License and log book for my own and Jamie Noonans car"
I feel the need for 5.4litres of V8 goodness!
2005 FPV BA MKII Pursuit
Build Number: 108
White
6spd Manual
100% Stock Standard... For Now...
DoggyGT is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 02:22 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
sheesh...
thats a very long list..
any ideas on how they got rid of it all? the recent spate of robberies/break-ins lately, it makes me wonder if its a clan doing all this
one day all these scumbags will be caught.. running a race company into the ground by stealing all their stuff they earnt, is not a joke..
assholes
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 02:31 PM   #3
DoggyGT
In Pursuit
DoggyGT's Avatar
No not sure just got emailed the list myself and thought I'd put I on here to reach a wider audience and hope someone can help, it's a low act and must be heartbreaking for all concerned, from the owners to the customers
Build Number: 108
White
6spd Manual
Old 12-03-2011, 02:35 PM   #4
buggo
[BU66OS]
buggo's Avatar
Far out that's below the belt. Did the team etch any 'signatures' on their work, might be easier to recognise their stuff.
Depending on how dumb/scared/smart the blokes who robbed them are some stuff might start being sold off right away, but they might wait for the heat to calm down and sell it in a few months, but risk being caught with a wearhouse full of parts.
If their a six pack short of a carton, try ebay.
I hope they get their stuff back, you would be so depressed if you lost your livelyhood like this. I hope the owner and his boys keep their chins up and get back on their feet making cars again soon.
FG XR6 Turbo Nitro
BA XR8 Manual
buggo is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 04:21 PM   #5
Stefan
Stefan's Avatar
Why would you not have adequate insurance to cover your business.
Good reason to quiz a workshop on their insurance cover when leaving your gear or car there.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 04:29 PM   #6
302 XC
Dont workshops have
"Vehicles stored at owners risk" signs everywhere
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 05:59 PM   #7
4117kev
If you have a look on www.dragster.com.au the full story is there. Insurance was something like $100000.00 a year which nobody could afford.
4117kev is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 06:08 PM   #8
Fev
Fev's Avatar
Originally Posted by 302 XC
Dont workshops have
It was engines. Those engines wouldnt be fully prepaid so the business would have heaps of bills to pay which would be paid on completion
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 07:01 PM   #9
302 XC
Was more the comment pertaining to storing cars in workshops
Seriously you commision someone to build your engine or car,who really asks about their insurance cover ???
"You dont have insurance"???
"Nah sorry mate ill go elsewhere"
Feel sorry for the business and im sure many others have lost out to the theiving mongrels in this world
Either from the blackmarket or insurance companies themselves
Old 12-03-2011, 07:22 PM   #10
4117kev
I have built engines in 40-50,000 range i now that my engine builder did not have the insurance to my engine let alone the rest of the engines in his shop none of them do because it is simply to expensive to cover.
"you don't have insurance"??
"Oh you can get it & my engine will cost me 4 times as much to build, hell yeh go ahead with it money is no issue".
Old 12-03-2011, 08:01 PM   #11
dave351cid
playing in my big shed
dave351cid's Avatar
http://www.dragster.com.au/modules/n...er=ASC&start=0
discussion thread from dragster forums including input from shop owners and customers, and a photo slide show of the shopon page 3. end of page 2 had desciption of how they got the stuff out.
sounds to have been pretty well planned out. gear is proberly in a container by now on its way overseas.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 09:22 PM   #12
Stefan
Stefan's Avatar
That's exactly how it is in the Building Industry I work in.
I certainly asked about security when my XY GT was being restored. And when my previous XY GT was in getting a paint touch up. And I spoke to my insurer to ensure the cars were covered.
And yes I would go elswhere!
Old 12-03-2011, 10:29 PM   #13
familybus
WTF thats not far from me!
how the **** do these clowns nick off with all this stuff and think they can use it all or sell it without raising suspisions?
im bettin the stuff is on a truck and half way to bum farked outback somewhere, or in a container ready to ship away!
its not like they can just chuck it on Egay or sell it localy to your average Joe
****** i hope they get caught
familybus is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 06:08 AM   #14
SIMBAD
RAPID GT-P
SIMBAD's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This thread: BA-BF diff cradle removal for diff bushes
Default Re: Stolen parts and equipment, Sydney
anymore news on this?
gees thats alot of gear to be cleaning out in a rush! these people must have been doing this for a while!
somebody out there are going to be happy with their new bargin!
Full Difilippo big boy exhaust /4.5" body ballistic metal cats / boss 315 plenum & twin throttle body coupled to bpr airbox / powerbond underdrives / herrod 290 cams / malwood opt 3+ / hrs Pegasus rims 19x8.5 front - 9.5 rear / nitto invo 245-35-19F & 275-35-19R / whiteline swaybars/ Under bonnet bling / 4.11 harrop truetrac
Enhanced by BLUEPOWER
supercharged 363 dart takes on au work ute http://fordforums.com.au/showthread.php?t=11342906
SIMBAD is offline   Reply With Quote Multi-Quote with this Post
