Old 25-05-2012, 05:36 PM   #1
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Default Ute liners - what do you think?
Hi folks, just wanted to get your opinion about plastic ute tray liners? I've just recently bought a 97 XH ute in mint condition with 118k's on the clock. As far as I can tell, she's never done any trade work - it's way too straight! The question is about the ute liner. Yeah, I reckon they look a bit trick - but I've heard that they promote rust due to condensation. Yes, it has a tonneau cover. Any ideas? Thanks in advance for your replies. Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 05:51 PM   #2
stalker
Default Re: Ute liners - what do you think?
my xf has a rubber mat on the base no rust under that... shouldnt be too bad with the tauno she would be right.
current ride:
92 Nissan GQ Patrol runs over 5h*T nuff said!!
ED fairmont awaiting alot of parts and some love (v8 love)
XF ute 4.0ltr injected out of an ed with girl cam and 5speed, and an xd front end for good measure
stalker is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 06:23 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
If you are talking about just a mat to cover the base of the tub, you can buy a rubbery material that has a circular design and is full of holes... won't be able to trap any condensation then.
___________________________
Old 25-05-2012, 06:35 PM   #4
stalker
i think his talking the inner liner much like the AU. hard plastic
current ride:
Old 25-05-2012, 06:36 PM   #5
supershifty
Missing a sock...
Sorry, I mean that the ute already has one of those "full tub" liners already fitted. The XH only came out in a styleside - most unfortunately. Would have been fully stoked if they came out with an alloy tray!
Old 25-05-2012, 07:03 PM   #6
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
I had a '97 XH ute aswell up until recently... was the best ute by far that I've owned, i regret parting with it!
Anyways, I considered a plastic liner but ended up going with a just a fitted rubber floor mat instead. 10 years of service and the tray looked nearly as good as it did when I got her.
I was also warned about condensation causing rust. also, I didnt like the idea of drilling holes to fix the tub.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 07:17 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Cant speak from experience with an XH but with the AU they do get lots of crud caught up underneath the plastic tub and the metal braces underneath it. If its left there for a long time it can cause rust.
I think if it were me I would spray the tub with some sort of protectant before fitting the liner.
2024 F150 XLT
