Old 25-05-2012, 06:55 PM   #1
Ezz
05 BF XR6T
Ezz's Avatar
Default Will KONIG 19" Rims fit an 02 Lexus IS200
Just wondering if someone could tell me whether or not these rims would fit an 02 Lexus IS200?
Konig 'Unknown' 19 Inch
I know they fit the stud pattern of Ford and Mitsubishi, just not sure about the Lexus? Cheers for ya help fellas!
2009 AUDI Q7 4.2 lt V8 Twin Turbo TDI S-Line BLACK
2005 Ford Falcon BF XR6 Turbo
Bionic 6 Speed ZF Sequential
340+kW @ the wheels @ 14psi
Brembo 6 Pots / ZF Tune
BIG Thanks to Chris & Theo
BLUEPOWER Racing Development
Ezz is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 06:59 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Default Re: Will KONIG 19" Rims fit an 02 Lexus IS200
The falcon and most toyotas where the same stud pattern, so my guess is yes.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 07:03 PM   #3
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Pattern is the same but from what i can find, stock Lexus offset is 50mm whilst AU+ Falcon is 36.5mm and those Konigs are more than likely 35mm.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 07:28 PM   #4
Ezz
05 BF XR6T
Ezz's Avatar
Ok, more info. They are: 19" x 8" (+40 offset) Front, 19" x 9.5" (+40 offset) Rear, 245/35/19
Do you think I can pull it off?
Old 25-05-2012, 07:55 PM   #5
Mr H
one way to find out......
Mr H is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2012, 08:01 PM   #6
Ezz
05 BF XR6T
Ezz's Avatar
And that is...? (No, don't ask me to try them first as they are in NSW.)
