Old 28-05-2013, 02:00 AM   #1
peterljohnson55
peterljohnson55's Avatar
Default Definitions re wheel alignment.
I am hoping someone can advise me of ... the two points/places between which the measurements are made to give the following "openings"?
Thanks for your interest...
"Fender Opening (Pin height)" in mm.
"Fender Opening (kerb height)" in mm.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2013, 06:59 PM   #2
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Default Re: Definitions re wheel alignment.
Fender opening is the wheel arch.
Pin would be the lower balljoint...So it's from the base of the lower balljoint to the base of the wheel arch
Kerb height would be from the ground to the base of the wheel arch....make sure you're on level ground for these measurements...
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 28-05-2013, 08:23 PM   #3
big_landau
dunno how to help with that but the best wheel alignment I have ever had was done by an old bloke around 20 years ago with a stringline.all this digital crap I have had and my car has not had the same results.i suppose it just goes to show a man with knowledge and experience can do a better job than a 19 year old punk with lasers.
ohh and before you ask yes I still have the same car.
big_landau is offline   Reply With Quote Multi-Quote with this Post
