Old 11-08-2013, 10:49 PM   #1
BlakesXR6
Default New coolant leak :(
So 2 days I installed a new waterpump which was leaking directly underneath which has now stopped. Now a new leak has formed, the coolant is currently over filled but it's leaking from around the sump area. The overflow hose comes out of the reservoir on the drivers side if I'm not mistaken, so I'm clueless to where it's leaking from.
Any help would be appreciated, you guys on Ford forums always give great advice
BlakesXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 11:29 PM   #2
mik
mik's Avatar
Default Re: New coolant leak :(
i would say before you start taking things apart go over as much of your work as you can to make sure every thing is tightened correctly, hose clamps, bolts, etc, check the o ring on the back of the water pump were the metal tube goes into it the pump, use a digital camera/smart phone to take some pics were you cant see properly and wack them on the pc to get a better look around, or use a small mirror and torch to check suspect areas and see how you go.
Old 11-08-2013, 11:30 PM   #3
GASWAGON
Take it to a mechanic so they can pressure test the cooling system and find where the leak is..... I'll bet its to do with your water pump replacement...Maybe faulty gasket?
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 09:59 AM   #4
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Radiator hose to water pump connection?
Its not uncommon for a hose to leak once its had its seal broken, especially if its been on a while and the rubber is crushed where the clamp goes.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 10:46 AM   #5
shazaam
Getting it up to temperature so the hose softens then retightening helps too. Have had to do this many times after taking off or replacing hoses etc.
shazaam is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 10:52 AM   #6
BlakesXR6
Thanks guys I'll try when I get home, this leak is in a different spot to where the waterpump was leaking last time so I'll go over all the hoses, just hope it's not the waterpump because replacing it last time was so messy and and fiddley
Old 12-08-2013, 01:42 PM   #7
BlakesXR6
So had a better look and it's coming from the back of the engine, thinking it's a heater hose maybe, I'll take to a mechanic when I get the chance
Old 12-08-2013, 02:08 PM   #8
Silver Ghia
Silver Ghia's Avatar
Rear welch plug maybe?
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 03:08 PM   #9
BlakesXR6
possibly, I don't know where exactly the Welsh plug is exactly, I've test drive it earlier, came back with no leaks...went back and checked again and again no leaks but last night I had a puddle, I'm so confused and this morning it was leaking down from the stabilizer bar and down underneath the ac compressor. No loss of coolant in the reservoir. I'm thinking maybe it's left over coolant from waterpump replacement, because I just dropped the coolant when the waterpump was removed so it went all over the frame
Old 12-08-2013, 09:02 PM   #10
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Condensation from air conditioning? Is the fluid on the ground anti-freeze, e.g red or green. If not its most likely condensation.
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2013, 09:37 AM   #11
BlakesXR6
Green coolant on the ground
Old 13-08-2013, 09:39 AM   #12
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Just reviewing your older posts this is a EF XR6 yes? Good idea mate if you can try and post in the relevant section so everyone knows what you're talking about
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2013, 11:27 AM   #13
BlakesXR6
Sorry Mr moderator
Old 13-08-2013, 04:05 PM   #14
99AUXR
Brad
99AUXR's Avatar
Get mechanic to pressure test, it will only take 20 mins of his time to let it sit and see if pressure leaks down, that way your mid will be at rest.
Old 13-08-2013, 06:49 PM   #15
BlakesXR6
The thing is its been weird its not leaking anymore, I'll keep an eye on it
