Old 16-08-2013, 06:40 PM   #1
phillford8
Default 347 windsor
hi this is my first post trying to find out some info from you guys.. im building a 347 windsor which is the motor out of my 93 xr8. its a auto scat crank and rods forged pistons .howard roller cam good for about 5800 Alloy heads GT 40 intake. just a good streetable engine . now the problem is im old school and have never played around with feul injection,, you know just bolt on a good intake manifolt and a holley carb ,get it jetted and away you go. now i got a 72mm throttle body and a 75mm MAF with the gt40 intake and i also have 24pound injectors
the standard throttle body is 65mm and the maf is 70mm. I tavent got a clue what to do about the computer and being a 347 will any of this intake hardware be suitable,,, any sugestions would be greatly appreciated.. thanks phill
phillford8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2013, 06:55 PM   #2
FTE-063
FTE-063's Avatar
Default Re: 347 windsor
i think you should post in the windsor V8 sections there's people that should help you out
a matter a fact i'll put it in the section for you . cheers dean
http://www.fordforums.com.au/forumdi...sprune=-1&f=11
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2013, 06:56 PM   #3
FTE-063
FTE-063's Avatar
it's in
Old 17-08-2013, 10:19 PM   #4
roberts
it will run on your eb injectors and maf, the ecu wont know its a 347.
it really is just as simple as jetting a carb, but you do this with a tuneable chip
roberts is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 05:20 PM   #5
phillford8
ok thanks guys for the advice steep learning curve for me.. lol
