Old 06-05-2016, 03:12 PM   #1
vanq69er
Default Brake Caliper Painting Melbourne
Hi all,
Sorry if this is the wrong section but I was wondering if anyone could recommend a place that does a good job of painting calipers in Melbourne?
They are brand new off the car and I want them done properly (IE not sprayed on the car).
Thanks
vanq69er is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2016, 10:35 PM   #2
Default Re: Brake Caliper Painting Melbourne
Why not do it yourself?
It's extremely easy, especially in your case if they are off the car, brand new with no brake dust, or dirt.
Just buy a spray can of Caliper paint for appromixately $20 from Autobarn or Supercheap, and also a spray can of Caliper Clear coat.
The Caliper paint dries very quickly, and you could have the job done in less than an hour and $40.
Otherwise if you want them done professionally .... Your local Panel shop will do them for you in no time.
Old 07-05-2016, 08:16 AM   #3
My32Doors
Ceramic coating is also an option. For example
http://www.hpcoatings.com.au/coating...-coatings.html
My32Doors is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2016, 08:50 AM   #4
uniacidz
uniacidz's Avatar
Even better if they are off the car.
Save a bundle of dollar doing it yourself.
Wax n grease remover, tape and cover any sensitive bits and paint
Dry in the sun being winter
Once installed, normal operation of heating up will cure the the paint.
Otherwise
First google search
http://www.easycalipers.com/
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2016, 10:32 AM   #5
vanq69er
OK I might give it a shot, thanks!
Old 07-05-2016, 11:21 AM   #6
OzriderXR8
OzriderXR8's Avatar
I done mine a couple of weeks ago and they were dirty after the first drive in the rain anyway. I only did mine black as they are too hard to keep clean.
I also painted the disks as they were new, wire brush and wax and grease remover first.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2016, 12:05 PM   #7
vanq69er
Otherwise
First google search
Yeah I did google it, they only paint on the car and it says int he FAQ that the backs of the calipers wont get done
Old 09-05-2016, 08:20 AM   #8
PooDog
PooDog's Avatar
easy as to do yourself , ive just done my rotor hubs and outside edge on a fgx as from the factory they come with just primer on and in my opinion they look cheap and nasty
i did mine red to match the brembos got it from supacheap reasonably close match ...they do get dirty easy ,ive got a handy wheel cleaner i made out of a plastic hand brush (hearth brush) type cut bristle part off so its thin then glue an xlo sponge on with some ados , awsome for cleaning inside hubs and skinny places on wheels ,when it wears out glue another on
PooDog is offline   Reply With Quote Multi-Quote with this Post
