Old 12-03-2021, 01:08 PM   #1
FoxtrotGolfXray 5.0
FoxtrotGolfXray 5.0's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willingly providing technical info and documents, despite glitches.
Default Ford Ranger Steering Arm Failures
The company I work for has an operational site in central Queensland. A flyer came out the other day detailing three separate incidents, across a period of 3 years, where an incident occurred with some of the Ford Ranger fleet that was attributed to steering arm failure.
The flyer states that the site will look to "replace it's Ford Ranger fleet as the leases are completed and swapping them out prior to this with Toyota Landcruisers from other site where possible. The Landcruiser has a thicker steering rod arm and is considered more suitable for rural driving conditions (twice as thick 12mm-24mm)".
I've had a look in the Ranger section here, but could find nothing related to this issue.
Is this a known or widespread issue with Rangers?
Labels are for jars, not for people.
Life is a journey, not a destination.
Daily: 2013 FGII EcoLPi in Winter White
Play: 2015 FG X XR8 in Emperor Show' N Shine thread
Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor
FoxtrotGolfXray 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2021, 02:08 PM   #2
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
Default Re: Ford Ranger Steering Arm Failures
No. I’ve never seen it.
Landcruisers might be built a bit more heavy duty but they certainly still break. Look up land cruiser diff failure or diff housing cracked.
Everything has a limit.
Landcruiser is also double the price and has wind up windows and ac is optional.
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2021, 04:21 PM   #3
Bolly47
Yes, I have seen it and replacing passenger side ldler Arm 3 or 4 time on my son's Ford Ranger They bend and jam up on the under the chassis*after 8 months of trouble my son sold it No matter what brand you buy still bending still too weak until new model has Rack and Pinion Steering is the way to go.Note I did the work, keeping replace until I told him that I had enough*too much BS so took to steering specialist and other fews weeks later bend again Just Faulty ford engineering*design.
Bolly47 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2021, 04:26 PM   #4
Magee
Magee's Avatar
If the failures are on fleet vehicles working in an off road application such as a mine site, then I would not read too much into for effecting privately owned vehicles that are driven on normal roads. Many years ago I did short stint in a Transport Workshop for what was then the SEC. Most cars just came in for normal servicing and general repairs, but it was clear that a few of the vehicles that came in were mechanically damaged by people who didn't have much respect for cars.
Magee is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2021, 10:17 AM   #5
mac_man_luke
mac_man_luke's Avatar
I did plenty of outback travel and hard 4wding when i had my ranger and never had any issues with steering arms (one of the few bits that had no issues haha)
Cruisers are tougher but i somehow managed to slightly bend a drag link on mine without even knowing it (only minor, showed up at a wheel alignment) but plenty of good aftermarket parts for them.
2015 Toyota Landcruiser 79 V8 SC
mac_man_luke is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2021, 11:16 AM   #6
ebv8
ebv8's Avatar
on one of 4wd24/7's YouTube shows they did one on a raptor, some mud driving and it snapped, used lots of ratchet straps to keep the wheel generally pointed straight
seems a bit off for a raptor to break suspension parts being hyped up so much
i'd be more worried about munching the torque converter or having a failed injector, my brothers car did both at 105,000km. luckily it was a lease car and i think ford ended up fixing for free ($15k quote)
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2021, 11:24 AM   #7
mac_man_luke
I wonder if the raptor is due to the significantly wider track but maybe same diameter rack ends/tie rods? they also tend to drive like morons
Old 15-03-2021, 11:52 AM   #8
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
I'm not familiar with the failing hardware however if it's a bolt on part can't someone (Ford??) make a more robust replacement?
If it's say 12mm diameter make one 18mm or 20mm and then provide those as a free upgrade to mining vehicles or any vehicles taken in for replacement after a failure?
Seems the cheaper option than losing fleet contracts?
___________________________
Old 15-03-2021, 12:24 PM   #9
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Cant see why not, they did it with SX/SY1 Territory ball joints, made a slightly stronger part and offered 1 free replacement.
Didnt help much, was just a crap design having the joint under tension as opposed to compression like SY2/SZ.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2021, 12:24 PM   #10
XR Martin
XR Martin's Avatar
Landcruiser has a solid front axle, so of course it's going to have a thicker steering arm (and completely different design)
But on the other hand if the Landcruiser's arm was 24mm mild steel and the Ranger's 12mm arm was Titanium, would the Cruiser's still be better?
I think not.
End of the day, a solid axle in rural conditions is far more durable.
2004 BA wagon RTV project.
Old 16-03-2021, 01:37 AM   #11
GCRXR6
GCRXR6's Avatar
A bit silly comparing a Ranger with a Landcruiser. A Hilux is more in the Ranger family. Hiluxes aren't unbreakable neither.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2021, 01:40 AM   #12
GCRXR6
GCRXR6's Avatar
Ahhh...what model Ranger are you speaking of? PJ on have rack and pinion....no idler arm on the P series.
Old 16-03-2021, 01:45 PM   #13
Bossxr8
Peter Car
Bossxr8's Avatar
Try hard enough and you can break anything. A friends brother who we sometimes go camping with can destroy anything. Drives like an utter mad man off-road. Hardly slows for anything. Just smashes it through creek crossings, drainage ditches, whatever. Has absolutely zero mechanical sympathy. Ended up with his Hilux's steering wheel in his lap when the steering column broke. He doesn't care. Breaks stuff constantly. Just fix it, and rinse and repeat.
I just don't get it. I just cringe watching him sometimes. It's brutal. No amount of engineering will stop these nutters breaking their cars.
Old 16-03-2021, 01:57 PM   #14
Tassie f100
I must have a rare bird then!! My 2009 PK has steering box and idler,complete with drag link and tierods
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2021, 05:40 PM   #15
PX onward have rack and pinion steering.
PJ and PK still had re-circulating ball.
DFB FGXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2021, 01:35 PM   #16
Vesper Martini
Vesper Martini's Avatar
Certainly cheaper than replacing a whole fleet due to 3 failures with a much more expensive vehicle. I guess they just needed an excuse
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2021, 07:06 PM   #17
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I love people like that, I'm one myself, my cars get absolutely flogged
Old 18-03-2021, 09:46 PM   #18
GCRXR6
GCRXR6's Avatar
My apologies. I thought when I read the OP, and thought, "Rack and pinion aren't they?" So I thought I had better check on Bing.(PJ PK Ranger steering) ... First was R&P, so I went by that. Ok Seems I muffed. I checked again tonight and bugger me, one site sells Racks for 2WD, and further down 4WD the ol' box and links. So yeah, "Sorry about that Chief." Are they indeed different from 2WD to 4WD?
