26-01-2006, 07:26 PM | #1 | ||
tuff
as the title says ,do you run it in hard ,i.e load it up everywhere etc ,or take it easy for the first 1000km then graduly go harder,
i beleive running it in hard is the best idea... what do you guys think? cheers
.......................FG XR6 UTE........................... ......................xc fairmont gxl......................... ...................GQ coil cab UTE .......................... |
26-01-2006, 07:30 PM | #2 | |||
AFF's 1st DM.......
Keep it underload but dont go rev'n it too hard or high.
I did this with mine, dropped the mineral oil at 500 then 1000k's after that i gave it alot more
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
26-01-2006, 07:43 PM | #3 | ||
You gotta pay to play
The last one that I ran in I towed a trailer the entire time, I did not drive hard and I did not drive soft.
Funny thing it was all in vain as my 1st maraige broke up just as I finished running the car in and I sort of forgot to mention that it required an oil change.
Regards Gilesie AU I Forte Wagon 4.0 Dodge D5N Twincab (Project) 2003 Mazda Bravo (work truck) 1979 F100 Ambo |
26-01-2006, 07:47 PM | #4 | ||
GT4.
I gave mine revs all throught the rev range and drove it slow and fast and on freeways and in the city. I never punted hard either until it was fully run in.
26-01-2006, 07:54 PM | #5 | ||
tuff
apparently its better to run engines in hard to seal the rings properly ,so that may be the go for me..
26-01-2006, 07:54 PM | #6 | |||
windsor user
and lol at forgetting:P |
26-01-2006, 07:56 PM | #7 | ||
351 cubes of power
run it pretty hard but no redline action or burnouts! if an engine is nursed to much and then you go to give her some hooter, it can be pretty bad. take danny's method..it's the right way to go
:sm_headba NO RICE AND NO RAP :sm_headba |
26-01-2006, 10:45 PM | #8 | ||
Hmmmm
drive it like you stole it, if its a new car, it will have a warrantee, so if u stuff it, no wukkas.
if its an old car, well it should be "classic not plastic" as the bumper sticker says and it should take a beating like a geelong wife. |
26-01-2006, 10:50 PM | #9 | ||
My current engine was run in on a dyno. Roughly 6 or so hours of running inc cam break-in. After that it did about 100k's driving, then I was out racing @ Heathcote. Motor was a week old.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
26-01-2006, 10:53 PM | #10 | ||
Keeping Wombats Dead
The guys I work with at a Ford dealership, in the Pre-Delivery department, rape the hell of every car they get when they road test it. These are cars with 0-40km's on the clock, so I guess if they do it, you should do it as well...
26-01-2006, 11:03 PM | #11 | ||
GT
drive it hard but no redlining . stay below 4000rpm till 1000kms .after this increase to 5000 rpm for 2000kms occassionally . then at 3000kms. go for it if it breaks then it was always going to . but they run in all the way up too about 15000kms.
26-01-2006, 11:23 PM | #12 | ||
run in secrets rip it's neck of and red line it..... And what this keep it under 4000rpm rubbish, if you want it to go hard, then drive it hard when running it in.
26-01-2006, 11:55 PM | #13 | |||
GT
26-01-2006, 11:59 PM | #14 | ||
Force Fed Fords
I keep the engine working through different rev ranges, dont push it beyond 3000rpm for first 1000k and then after 1500k is open season. Never idle it for too long or stay at same speed in same gear for too long. Have run in 14 new Fords this way and all have come through well and none have missed a beat!
2021 Focus ST-3 Mountune Enhanced |
27-01-2006, 12:00 AM | #15 | |||
Shoot.
20V Turbo |
27-01-2006, 12:01 AM | #16 | ||
If you treat them too kind? You'll glaze the bores which shortens engine life. My prior engine I ran in driving it like I stole it. Ring seal is the key to extended engine life.
27-01-2006, 10:24 AM | #17 | ||
V8 Rock'n'Roll....
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
As a mate of mine (who owned and built race engines for drag, circuit and speedway as well as some hot rod work) once told me, "Let it warm up properly, then load it up as much as you can without bouncing the valves". Remember you also need to get the gearbox and diff temperatures going as well for any hi-po work. If you don't believe this, look at Ferrari, their cars now won't let you use over about half revs until engine, gearbox and diff are up to temp, then you can run it as hard as you want, straight from factory.
1 owner 03 BA XR8 Manual Sedan 208.8 rwkw stock, update soon 20x8.5 fr 20x10 rr Rumble thanks to: Sureflo Exhaust - Stainless Cat's & 3.5in single catback system "Tell 'em the guy with the Blue Mohawk sent Ya" |
27-01-2006, 10:41 AM | #18 | |||
The exchange engine I let my wife drive at the start .. bad move. She pottered about in it and it started using a LOT of oil. Between that and a leaking rear main/sump .. it used about 1litre in first 1500km. Things looked bad, so after the rear main/sump fix I drove it "spirited" again whenever I go the chance and it's stopped using oil (I think?). Moral is, yep drive em hard(ish) or they'll glaze up the bores and be an unhappy engine .. |
27-01-2006, 11:12 AM | #19 | |||
27-01-2006, 11:39 AM | #20 | ||
FTF Club Moderator
That was a really good read Jabba. I have never had to run a car in because I have never owned a new car.... yet....
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
27-01-2006, 11:51 AM | #21 | ||
Performance moderator
Give it heaps, well 85 % so rings bed in BUT only for short periods so rings don't get too hot.. Its the first 200 klrs that counts..After that the honeing on the bore is gone and it won't make any difference after that...Manufacterers tend to fit soft low tension rings these days with much much lighter noneing..All goood for bedding in etc..But at 100.000 klrs the rings can be stuffed but still run...
Some engines with liners as bores like Subaru have hard bores and take longer to bed in.. The gen lll may be the same? My Dart block has heaps hard bores also.. Don't use synthetic oils until 5.000 klrs...
27-01-2006, 12:05 PM | #22 | ||
interesting to read all your opinions
id be inclined to baby it for a few thousand k's but i don't really know much about engines ive heard people say if you want it to go hard belt it when you get it but i don't like belting my car regardless also i drive my i6 eb around barely using any throttle for extended periods of time...my fuel av in 9.8...will this do any damage? |
27-01-2006, 12:26 PM | #23 | |||
V8 Rock'n'Roll....
27-01-2006, 12:39 PM | #24 | ||
Haltech 302w XW
Load it up....
When my car is running again...has had a brand new engine...but rebuild with cam. better rod blts... oil pump etc.... see signiture for details...will be getting run in with a l8 night trip to the Glass house mountains. lots of hills to load it up on no traffic to get stuck in and 100km/h speed limits.... prob wont be finished un til march though...all the waiting is killing me though.
1969 XW Fairmont-1999 explorer 5.0- comp cam XE270HR, 9.8:1comp, Ported Gt40p, Ford Racing oil Cooler, EL V8 radiator & thermo's, Fuel/intake -XR6T injectors, 255 LPH intank pump, 4" intake, HaltechE11v2 Exhaust-custom Tri-Y headers, Twin 2.5" HiFlo Cats, duel 2.5" exh Driveline-close ratio 4spd, 9" LSD, 300mm AU XR8 fr, XC rear, ZH Fairlane Mas/Cyl & Booster Project car: http://www.fordforums.com.au/showthread.php?t=21641 |
27-01-2006, 01:27 PM | #25 | ||
The one and only
I easy mine. Remember the bearings are very tight.
After first petrol tank I go harder and third tank is red line, dyno etc.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
27-01-2006, 01:38 PM | #26 | ||
I know of people hitting revlimit leaving the dealer in brand spankers..and there cars are now freakishly quick, with no problems 40,000k's later..
I also know of poeple putting and babying there cars for 2000k's before giving them a rev and the first time they rev em out something goes wrong, and they continue to have problems when driving hard.. Id suggest drive it hard, but not thrash it.. set a real standard for it, or do what Brenx did and run it in on the dyno.. |
27-01-2006, 03:55 PM | #27 | |||
AFF's 1st DM.......
Is the procedure the same for those that run moly rings, as ive heard it takes longer for them to bed in than it does iron
27-01-2006, 06:13 PM | #28 | ||
Central to all beach's
From my experience, it seems that working the engine without lugging it is the way to . I had a new engine in my C172 about twelve months ago. The lame stressed to cruise at 100 rpm higher than normal for the first 50 hours. The engine had special oil in it called red band. Not had a moments trouble since.....
27-01-2006, 09:49 PM | #29 | ||
tuff
cheers for the replys ,just drive it hard .but at the moment my car is in the process of being panel beated etc ,has and will do alot of start and stop and mainly idling for the next god knows how long ,do you reckon this is a bad thing ,i do cause its just idling no load so yea...
27-01-2006, 09:51 PM | #30 | ||
LPG > You
FPV's recommended run-in prodcedure for the Boss-290 V8 can be seen here... http://www.fpv.com.au/index.asp?link_id=2.419
LPG Lovers Association President & Member #1. : |
