Old 28-01-2006, 09:29 AM   #1
merlin
merlin's Avatar
Default THIRSTY WORK - Holdens new V8
Drive article here: Holdens New 6L - Thirsty Work
FULL TEXT HERE:
Thirsty work
The Sydney Morning Herald
Friday January 27 2006
Holden's new V8 likes an expensive drink, writes TOBY HAGON.
With petrol prices hovering at record highs, Holden has introduced an engine which could cost Commodore owners even more money to run.
The all-new, 6.0-litre V8 - which has been introduced because the previous 5.7-litre V8 does not meet the latest emissions standards - could cost owners almost 10 per cent more at the bowser because the engine's full potential is only reached when using the top-grade 98-octane premium unleaded fuel - and it is slightly thirstier than the previous V8.
According to Government-supplied figures, V8-powered Commodores with automatic transmission now use 14.0 litres of fuel for every 100km travelled, a modest increase on the 13.9 litres/100km consumed by the 5.7-litre V8.
However, once you fill it with the 98-octane petrol (which costs about 10 cents a litre more than regular unleaded) recommended in the Holden brochure to achieve the claimed 260kW of power and 510Nm of torque, the newest engine in Commodore V8 automatics could cost about $300 more a year to fuel (based on an average annual distance of 20,000km travelled).
Holden says the new V8 will run on normal unleaded petrol but maximum performance is only achieved with the more expensive premium unleaded. Holden would also not disclose how much power the engine loses when using normal unleaded petrol.
Holden engineering group manager for engines and transmissions, Simon Cassin, concedes the new V8 engine is thirstier in some situations, although he says that running on higher octane fuel will also bring some fuel economy benefits, which would make the running costs fractionally more attractive.
How much exactly? "We don't know," Cassin says. "To work that out you would have to run back-to-back tests with the same fuel and (in the same conditions)."
He says that the new 6.0-litre engine will be more efficient in some situations, saying it is "swings and roundabouts".
"[The Government test is done on] a very light load drive cycle. The heavier use [more aggressive driving] the customer exposes the car to, the greater the benefit from the 98 RON fuel, for both performance and fuel economy."
The new 6.0-litre V8 was developed with fuel-saving technology that shuts down up to four cylinders under light cruising load or when driving downhill. But Holden has not opted for this fuel-saving "displacement on demand" technology, instead perhaps leaving that card up its sleeve for the all-new VE Commodore due in August.
According to Holden's marketing manager for large cars, Philip Brook, most buyers will be prepared to spend the few extra dollars a week to get a car with better performance.
"For the majority of buyers, performance is the key point," Brook says. "Sometimes there's a slightly higher cost associated with that higher performance."
He says that the extra running costs are "pretty marginal and it depends on what model it is", while also stressing that in "real world" driving different results can be obtained.
Holden is expecting the extra performance of the new V8 - power is up 4 per cent and torque up 8.5 per cent - to boost sales of its hero models.
"We don't expect [the extra running costs] to be a big issue because we think it delivers a pretty significant boost in performance," Brook says.
The added running costs are not as significant for new V8-powered Commodores fitted with a six-speed manual transmission, which get a taller final drive ratio to ensure the engine doesn't work as hard.
Fuel economy has actually improved by 1.4 per cent, although it could still cost more to run - as much as $240 a year based on average annual distance travelled of 20,000km - if 98-octane premium unleaded is used.
Production of automatic versions of the 6.0-litre V8 begin next month, with dealer deliveries following in March. Production of manual versions of the 6.0-litre V8 begin in March, with dealer deliveries beginning in April.
The new 6.0-litre V8 is available on Berlina, Calais, SV8, SS, Statesman, Caprice, SS ute and Crewman SS models at a slight price increase over the previous V8.
Although they are the same capacity, Holden's new engine is not the same 6.0-litre engine fitted to Holden Special Vehicles models. That so-called LS2 engine is sourced from the Corvette; Holden's 6.0-litre (codenamed L76) was primarily designed for use in four-wheel-drives and pick-ups in the US.
Holden is the first brand in the General Motors family to use the new engine.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 10:23 AM   #2
Rodp
Regular Schmuck
Rodp's Avatar
Meh, fluff piece. My Gen3 would knock unless it had premium in it and you'll likely find most people on LS1.com use premium, as would a good chunk of people on here that run V8's.
If you use unleaded, you don't get the quoted performance figures. Gee, how's that different to a Gen3 or a Boss now? If you're buying a V8 I doubt you'll care about the 0.1l/km increase in fuel consumption. Philip Brook's quote is right on the money.
Old 28-01-2006, 10:49 AM   #3
MAD
Petro-sexual
MAD's Avatar
Hrmm, wouldnt a large company like holden have an indoor/climate controlled facility for such a required situation.... Ford does.
In other words the answer to the question above = next to stuff all.
- The Story
Old 28-01-2006, 11:02 AM   #4
Dodge
i like to be stroked
Dodge's Avatar
ill take a 6ltr berina , Ony Hemi has the 4 cyl shut down engine, Holden doesnt ...,...Na Na
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying "Damn...that was fun!"
Dodge is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 12:15 PM   #5
Gabbs
Curry in a hurry
Gabbs's Avatar
I thought they would have started production straight away.
Should be interesting to see if they increase the power come ve. Ford have had the same power in the v8s since thier launch in ba.
Gabbs is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 12:23 PM   #6
Racecraft
they call me Tibbo
Racecraft's Avatar
quoting the 98 price is crappy.. As Rodp said, a very high percentage of newer car owners would be on premium fuels and the like anyway.. To insinuate it is the fault of the new powerplant is abit weak imho
Old 28-01-2006, 12:34 PM   #7
Lukeyson
Right out sideways
Lukeyson's Avatar
its a bee's male sex organ difference, they are clutching at straws IMO.
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 12:51 PM   #8
4Vman
4Vman's Avatar
Hardly surprising IMO.... Bigger motor is allways going to be a bit thirstier.
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 02:53 PM   #9
gmhdriver
gmhdriver's Avatar
0.1 litres per 100km... WOW. It probably wouldn't even be noticed in real world conditions. The article is making it sound as if the fuel comsumption has gone up by 10 litres or something. Typical bloody journalism.
gmhdriver is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 03:08 PM   #10
WASP
Whipple Induced
WASP's Avatar
These Journo's. There making it sound like people are being FORCED to buy these cars. We all have a choice for Christ sake. So much for supporting the local car industry. Shame.
“You can't build a reputation on what you are going to do.- Henry Ford”
WASP is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 03:09 PM   #11
aimzes
...fairly odd
aimzes's Avatar
exactly. and if using .1 of a litre more than a 5.7 discusts you, keep your old commo or buy a 6 lol.
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
aimzes is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 03:21 PM   #12
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
I love how the article makes out that the people purchasing the V8 are worried about fuel efficient.
If you want fuel efficiency buy a small 4 cylinder car.
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 04:58 PM   #13
Steve
torque is your friend
Steve's Avatar
Another journo with nothing better to report on. Buyers have a choice what they can buy. I'm sure if they wanted a large car with some go but good fuel economy as well, they can go for the six (in both red and blue flavours).
Support Cystic Fibrosis Australia
Learn about it here, donate and help the research into finding a cure and to provide services for children living with CF and their families.
Steve is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 10:05 PM   #14
SSBUB
SSuper SSpy
SSBUB's Avatar
im glad even the die hard ford supporters can even see this article as a bit of rubbish....5.7 l to 6l is not a huge mark-up and if it worries you, then why buy a v8 in the first place? V8's arent made for fuel efficiency even though they arent as bad as most would believe.
SSBUB is offline   Reply With Quote Multi-Quote with this Post
