Old 30-05-2006, 07:11 AM   #1
ubeaut302
Default Did ford make a small port 4v head
G'Day all
Wondering if anyone has come across any 2v heads marked as 4v?
I have some heads that are slightly larger in port size(approx 5mm wider and 3-4mm higher in the inlet port size) than a 2v but have a 4 casting in the corner where they should be. They have double valve springs and different retainers from standard 2v heads but that can be changed at anytime.
Using the numbers on the block it is not a GT block. I got it out of a ZD fairlane but it is originally out of a XB panel van going by the JG No
ubeaut302 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2006, 07:31 AM   #2
LTDHO
The one and only
LTDHO's Avatar
You'd get more of a response in the Clevo Forums. There a few Clevo wiz's there
Off memory, I don't think 4V's are marked. :
Tuned by CVE Performance
Old 30-05-2006, 11:54 AM   #3
ubeaut302
Thanks i'll give it a try there
