Old 24-03-2005, 06:09 PM   #1
RPO83
ĕm-bär'gō? 2016
RPO83's Avatar
Default Ford Commemorates 80 Years on the Line
Ford Motor Company is today commemorating 80 years of operation in Australia and a proud history that reflects the transformation of automotive manufacturing in this country.
Ford Motor Company of Australia was incorporated on March 31 1925 in Geelong, Victoria and almost immediately began assembling Model T cars in a temporary plant in Gheringhap St, virtually opposite the site of the Ford Discovery Centre today.
In the following 80 years since that momentous day for the Australian motor industry, Ford has been at the forefront of innovation, design and manufacturing in this country. It has a proud history of producing affordable, reliable transport for generations of Australians.
That first assembly line compared with today was a very crude affair with vehicles being pushed by hand from one area to the next as they were assembled. Only one model was available – the ubiquitous Model T. It came with several different body styles but the choice of engines and transmissions were limited to one of each.
Assembly of the Model T was a simple task. Huge crates were offloaded at the nearby wharf from ships that came from Ford of Canada. Chassis components, engines, transmissions and rear axles were unpacked and stacked alongside the 40-metre line (see images attached).
Workers used hand tools to bolt the components together and a block and tackle to lift the assembled body onto the spindly chassis. All the upholstery was hand stitched and the body frame was made of wood by skilled craftsmen and supplied by an outside vendor until Ford’s brand new factory was finished on Geelong's Melbourne Road.
As each car was built, it was pushed out the door and across the street where it was either driven to the railway station or picked up by a dealer.
Over the years, Ford introduced many innovations and new technology into the manufacturing and assembly process (see attached historical time line). In 1936 it was the first Australian manufacturer to replace the wooden body frame with an all-steel frame with the body panels welded to it.
One year later, Ford installed a massive stamping press that was capable of stamping the entire roof panel of a Ford V8 sedan in one piece – and so was born the complete steel body as we know it today.
Ford’s engineers were constantly improving the assembly line process to increase production and improve the quality of the vehicles. When the first Model T rolled out the door of the temporary factory in Geelong in July 1925, production was around thirty vehicles a day.
Today, Ford’s huge assembly plant in Broadmeadows on the outskirts of Melbourne builds 500 vehicles a day. The whole assembly process is extremely well organized – it has to be! Controlled by a master computer, dealer orders from all over Australia are programmed into a production sequence.
Up to 20 different models are built on the same production line, ranging from Falcon sedans, wagons and utes, Fairmont Ghia, Fairlane and LTD luxury vehicles to Ford’s new award-winning Territory Sports Utility Vehicle.
Each different model comprises different components, colours and trim levels. To manage this complexity, each vehicle has its own 'identity card', which specifies the exact component to be fitted. With more than 4000 individual parts in each car, there is no room for mistakes.
Ford uses a "Just In Time' supply system to deliver components to the assembly line. Rather than waiting for parts to be transported from other locations, suppliers can transfer their products directly to the production line as they are needed.
Each new Falcon or Territory that starts down the assembly line at Broadmeadows passes a bar code scanner. This triggers an electronic data message to each on-site supplier, specifying the model, trim level and suspension requirements.
Ford was the first assembly plant in Australia to use robotics and today 123 robots (compared with 50 just five years ago) undertake work such as welding and painting.
Most importantly, the lives of people on the assembly line have improved dramatically. Gone are the images portraying manufacturing as dirty and dangerous. Today’s modern facilities provide bright, clean, healthy and safe workplaces compared to 80-years-ago when there was little understanding of the importance of the workplace environment.
The modern assembly line is a far cry from the crude line where men pushed the cars along in often-hazardous conditions. High-technology robots have replaced the hand tools, sophisticated water-based paints and automatic paint systems have replaced the original lacquer and brushes, and computer-driven machinery produces thousands of seat and door trims from materials never dreamed of in 1925.
While proud of past achievements, today's Ford employees are already looking to the future and are developing the technologies that may one day shape the workplace of 2085.
RPO83 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 06:16 PM   #2
FordFan86
meow
FordFan86's Avatar
That was a good read... GO FORD
/me waits patiently for images
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 06:49 PM   #3
RPO83
ĕm-bär'gō? 2016
RPO83's Avatar
Image 1: The boot lid on sedans and the rear door on station wagons are fitted to the car
Image 2: Robots weld on the roof panels of the vehicle body
Image 3: Once the dashboard is fitted the centre console goes in, including the gear stick
Image 4: The cars undergo a final inspection before shipping to dealerships
Image 5: The engine and drive shaft are lifted into place in the car body
Image 6: The wheels are fitted and secured to the car using modern hydraulic systems
Old 24-03-2005, 06:59 PM   #4
dogbreath_48
dogbreath_48's Avatar
Yeah good read! Thanks!
i want that impact wrench!
-Stu
dogbreath_48 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 07:14 PM   #5
Kryton
Kryton's Avatar
very good read.
but in pic 5 the guy isnt wearing safety boots.
yeah i know im picky~!
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 07:17 PM   #6
FordFan86
meow
FordFan86's Avatar
there are shoe's that are steel capped which meet the requirements ;)
Old 24-03-2005, 07:18 PM   #7
Kev_BLNXR8_Ute
Hmm Project XW VAN !!!!
Kev_BLNXR8_Ute's Avatar
Hmmmm good reason for another show day on the shore......................
I'd rather be BLOWN than stroked
Yella Terra Supercharged
Power Output?
ENOUGH TO BREAK EVERY THING MORE TIMES THAN I CARE TO COUNT
POWERED BY VISA MASTERCARD AND MORE VISA
(And now a mortgage extension)
Disclaimer :
: Anything that seems or sounds illegal is all in my head and due to an over active imagination... :
Kev_BLNXR8_Ute is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 07:25 PM   #8
rob_o
rob_o's Avatar
Gotta love that impact wrench! All 5 at once!
rob_o is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2005, 10:56 AM   #9
DRU842
Can I just say I'm disappointed (not in the 80 years, get that into you GMH!) but in the fact the Ford Australia have not celebrated this event with the faithful (us!!), the way that they did the 75th Anniversary.
For those who weren't there the weekend was fabulous; Friday at the Broadmeadows plant with 5,000+ Ford groupies, Saturday down to the You Yang proving course, including a lap of the banked circuit & Sunday down to the Geelong waterfront for the biggest Show & Shine. Great people, great company, great cars!!
Oh to have it happen every 5 years!!
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel.
DRU842 is offline   Reply With Quote Multi-Quote with this Post
