Old 07-09-2007, 08:49 PM   #1
IAMSARANTOS
FULLY XR6
Default ef xr6 replica as to original
can some help me to determine an original xr6 as to a replica
cheers
IAMSARANTOS is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 10:38 PM   #2
b2tf
not here much anymore
b2tf's Avatar
easiest and most accurate way - get the VIN of the car and call 13FORD, they will be able to tell you if it is an XR6 or not, what options it has etc etc.
2024 F150 XLT
Old 07-09-2007, 10:42 PM   #3
TwistedEL
TwistedEL's Avatar
The body kit and a big old "T" stamped on the head would be a pretty good indication too.
Old 07-09-2007, 10:49 PM   #4
b2tf
b2tf's Avatar
Bodykit was optional, first XR model to have it standard was BA.
"T" cast into the head is a good indicator but it can be done pretty easily with a head swap.
2024 F150 XLT
Old 07-09-2007, 11:01 PM   #5
TwistedEL
TwistedEL's Avatar
Sorry you're right I meant the XR front end
It's not a 100% guarantee but it's a good indication.
To be totally sure you would have to check the VIN on the compliance plate, match it up with the panels and the engine number stamped on the block, then call Ford to confirm.
Old 09-09-2007, 04:40 PM   #6
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Model number on the compliance plate, have a look in the "Technical Resources" section of the Forums to find out what it should be
